RC MULTIKOPTERI => MULTIKOPTERI GENERALNO => Topic started by: mikijus on September 04, 2016, 06:36:39 PM
Title: QX90 - dali ga neko ima
Post by: mikijus on September 04, 2016, 06:36:39 PM
ceo net bruji o njemu...
 nadam se da ce mi ovo stici do kraja oktobra
http://www.banggood.com/Tiny-QX90-90mm-Micro-FPV-Racing-Quadcopter-BNF-Based-On-F3-Flight-Controller-FrSKY-Taranis-X9D-p-1069614.html
i modul za  turnigy 9xr
http://www.banggood.com/FrSky-DJT-JR-2_4GHz-Transmitter-Telemetry-Module-p-954940.html
i cvike naravno :)
http://www.banggood.com/Eachine-VR-D2-5-Inches-800480-40CH-Raceband-5_8G-Diversity-FPV-Goggles-with-DVR-Lens-Adjustable-p-1074866.html?bid=5182
sve zajedno oko 150 e
Title: Re: QX90 - jel ga neko nabavio
Post by: zloxi on September 04, 2016, 06:55:02 PM
Moju dnevnu sobu krasi:
https://www.graupner.de/Quadrocopter-Alpha-110-FPV/S5012.FPV/ (https://www.graupner.de/Quadrocopter-Alpha-110-FPV/S5012.FPV/)
Ponekad i po parku  ;D ;D ;D
(http://fs5.directupload.net/images/160904/ui9wvkwh.jpg)
Post by: mikijus on September 04, 2016, 07:14:58 PM
daj neki video...
Title: Re: QX90 - dali ga neko ima
Post by: zloxi on September 05, 2016, 08:10:06 AM
Evo sa neta (snimicu svoj ovih dana)
https://www.youtube.com/watch?v=SGwrJETDTaY (https://www.youtube.com/watch?v=SGwrJETDTaY)
https://www.youtube.com/watch?v=QwkMs8-_Uxw (https://www.youtube.com/watch?v=QwkMs8-_Uxw)
Mali ubija, neunistiv je i full acro po potrebi  ;D
Post by: zloxi on September 05, 2016, 08:10:57 AM
Inace imam i Walkera Rodeo 150 sa kojim sam imao pocetne probleme ali sad razvaljuje i ne zaostaje nista za F210 3D od walkere :)
Rodeo: https://www.youtube.com/watch?v=EAkgXyQemCo (https://www.youtube.com/watch?v=EAkgXyQemCo)
F210 3D: https://www.youtube.com/watch?v=X8vWM6gdaDY (https://www.youtube.com/watch?v=X8vWM6gdaDY)
Post by: mikijus on September 05, 2016, 10:12:11 AM
da se vratimo na temu
evo ga i na hobbyking-u i jeftini je
http://www.hobbyking.com/hobbyking/store/__110056__Tiny_QX90_90mm_Micro_FPV_Racing_Quadcopter_FRSKY_RX_B_F.html
ali ima jedan mali problem :
Sorry, we are unable to ship to your country. This may be caused by oversized parcel or dangerous goods such as battery or glue.
 do sad mi se ovo nije desilo ...
Post by: zloxi on September 05, 2016, 10:50:00 AM
Jako mi je zao sto ne mozes da porucis  :'( :( ;D
Post by: mikijus on September 06, 2016, 02:18:09 PM
evo sta sam narucio :)
http://www.aliexpress.com/item/Tiny-QX90-90mm-Micro-FPV-Racing-Quadcopter-BNF-Based-On-F3-Flight-Controller-FrSKY-Taranis-X9D/32706330642.html?spm=2114.13010608.0.55.EF211g
i naravno bolje elise
http://www.banggood.com/Hubsan-X4-H107D-FPV-RC-Quadcopter-Spare-Parts-Blade-H107D-a06-p-911713.html
sve za 94 e
Post by: marko.jovanovic on September 07, 2016, 06:57:55 PM
Malo samo da vas odvedem od te priče da pogledate uslove u kojima su pravljeni snimci kada se letelo.
Vetar 0
Videćete kada dune malo jači vetrić kako će da se ponaša.
Nema sreće u  fpv racing-u bez pravih 1806 ili 2204 pa naviše motora.
Sve ostalo su puke improvizacije i nije ni čudo što toliko koštaju. Može se trkati na stazi i sa fićom i sa ferarijem to niko ne spori samo je pitanje ko će kako proći koji će rezultata da da.
Da ne pričam o trajnosti motora koji su ugrađivani, integrisane elketronike.....
Motori su danas toliko uznapredovali da čak i kinezi prave dobre stvari za male parice, esc-ovi i flight controleri takođe jedino što je slaba karika kod FPV quad-ova jesu frejmovi i ako želite da divljate tu treba da se isprsite za nešto renomirano i jako u protivnom će vas jeftine varijante skupo koštati a vreme će pokazati da sam u pravu.
Ono za hale i zatvorene prostore je savršena igračka ali ko danas ima napuštenu halu i gde?
Post by: Asterix on September 07, 2016, 09:14:53 PM
Vetar 0
Nebih se slozio sa tobom pogotovo za ovo
Zbog ogranicenja u americi za registraciju od 250g pa navise po modelu sve vise i vise su popularni manji fpv kvadrici, znaci postoje i manji brushless motori 1804 1707 1407 1306 1104/1105 koji su i napraviti za kvadrice 180 velicine i manje, tj za 3 i 4 incne propelere.
Ovde je u pitanju klasicni popularni brushed motor 8520, koji svakako ne moze da se poredi sa brushless motorima ali za indoor letenje je savim ok.
Ja sam razmisljao o ovom quadu jer imam za njega vec baterije propelere motore frsky stanicu... ali mi nesto video predajnik od 25mw ne uliva poverenje. Jer imam slican mali quad sa brushless motorima i video predajnikom od 600mw i opet imam dosta smetnji cim quad zadje za neko drvece travu...
Post by: marko.jovanovic on September 08, 2016, 07:44:23 AM
Pa o tome vam i pričam.
Znam ja vrlo dobro šta postoji od motora ali rekoh već gore pogledajte uslove pod kojima su leteli.
Znači nikako nije preporučljivo za poljanu sem kada su uslovi 0 vetar.
Indor ok mada i za njih bi se pre opredelio za neki bezčetkaš.
Motori sa četkicama ne traju dugo pogotovo sa velikim KV brojem i sa divljanjem tipa FPV raceing.
Integracija je kao što rekoh takođe veliki problem kod skrkavanja modela a neminovno je da se to desi pogotovo kada se leti po halama pa se opali o neki stub, lim....
Post by: mikijus on September 10, 2016, 09:34:35 AM
mikro fpv quadovi su buducnost....
u sve vise zemalja propisi idu ka tome,a da ne govorim kod nas.....
naravno da su ovo deciji motori i smesan video link, ali ako kupujes ovkvu igracku planiras da kupis 5-6 rezervnih motora... imam 4 rc aviona raspona krila 2 metra , proizvodili smo i prodavali multicoptere na apm 2.6 koji nose i po 18 kg (televizijama)
imam nekoliko quad-ova baziranih na apm 2.6. koji imaju link na 5.8 od 1w
i pored svega ne mogu da docekam da mi ovaj malisa dodje....sa mojim modelima svaki ozbiljniji pad puno kosta a ovo sam narucio za 54 e...plus ide i lose vreme letece se po kuci i oko nje :)
i da mozda naj bitnije raspitivali smo se u par garaza da nam daju nocu da letimo...i u principu moze
 samo u mom krugu prijatelja naruceno je 5-6 qx90 ,a vecina nas je u ovom hobiju ceo svoj zivot jos od modelarske sekcije znaci bar 35 godina :)
Post by: zloxi on September 10, 2016, 11:19:51 AM
A jesi porucio i one Eachine FPV cvikere sto od njih dobijes rak ociju ili imas vec neke mocne?  ;D
Post by: mikijus on September 10, 2016, 11:28:18 AM
porucio sam ove nove njihove na popustu za 63e :
a i ovo se pojavilo :)  .... nikad kraja
http://www.banggood.com/Eachine-Tiny-QX95-95mm-Micro-FPV-LED-Racing-Quadcopter-Based-On-F3-EVO-Brushed-Flight-Controller-p-1085818.html?p=%21908051276812013026G&utm_source=tradetracker&utm_medium=tradetracker_SE&utm_campaign=tradetracker&utm_content=227736
Post by: zloxi on September 10, 2016, 12:00:32 PM
A ovo?  8) 8)
"Ml-130"
http://www.directupload.net/file/d/4474/v2spewgd_jpg.htm (http://www.directupload.net/file/d/4474/v2spewgd_jpg.htm)
Postoje Fatshark cvikeri a postoje i oni drugi  ;D :P
Post by: mikijus on September 10, 2016, 12:26:05 PM
slazem se i nadam se da su ovi medju boljima od ovih drugih :)
Post by: marko.jovanovic on September 10, 2016, 06:36:25 PM
Ne vidim zašto bi se poredili quadovi od 18 Kg i nešto što koristite za jurnjavu.
Kada počnete da divljate sa tim krševima shvatićete da motori nisu jedini rezervni deo koji će vam trebati.
Ali samo polako. Pre nego što bacite novce iako ih imate sedite razmilite dobro o svim mogućim problemima koji će da vas zadese kada krene race.
54 eura nije nikakva velika cifra i to se slažem ali 54 po 54 izaćiće vrlo brzo na pristojnu cifru koju bi inače trebali da izdvojite za iole kvalitetan miniquad koji može da izdrži štošta ali zato i košta.
ZMR recimo ima sjajne frejmove za male novce ali kada ga otkineš o nešto pošteno vidi se kvalitet.
Pa kada krene adrenalin, pa kada se motori nameste da stoje pod uglom ne bi li se dobilo još malo brzine pa kada krene jedan tuć o betonski stub u garaži, pa drugi, pa treći.... E onda novčaničić samo se prazni.
FPV race nije samo ono što se vidi po video snimcima na youtub-u u što uglavnom prave snimke letova iz delova gde su jedan segment radili po 20 puta najmanje da bi ispao kako valja i onda uklopili u celokupan video....
bar 90% je takvih snimaka. Retki su oni majstori čiji let ide u cugu sa nenormalnim akrobacijama.
A i oni su pre toga izbunarili dobro nočanike......
Za iole ozbiljnu jurnjavu pogotovo po garažama kako planirate da radite ja bih 3 puta razmislio koji bi pre svega frejm stavio.
Baš gledam ovu verziju q95. Prvi ozbiljniji pad illi udarac o nešto ima da odlomi motor bar jedan, ruku, kameru, transmiter. Što onda izađe vrlo jeftino.
A na q90 šanse da preživi eventualo ima samo FC
Pogledajte malo kanal https://www.youtube.com/user/RCModelReviews/videos
Čovek vam je predstavio gomilu dobrih i loših miniquadova...
I što reče drug Zajko. PARICE SU VAŠE!
Ja samo dajem mali savet a ko hoće nek posluša a ko neće poslušaće sigurno malo kasnije!
Post by: mikijus on September 10, 2016, 08:19:35 PM
hvala na savetu :)
imam kuci delova samo mi ram fali da sastavim ozbiljnijeg trkaca na apm 2.6.platformi ali ga ne bi smeo ni da probam po kuci...
ovo gledam kao jeftinu igracku za po kuci i da vidim koliko mi se svidja fpv jurcanje
pa onda ako se primim na to nabavi cu nesto ozbiljnije neki 180 mozda..
Post by: marko.jovanovic on September 10, 2016, 08:35:24 PM
Gubiti vreme i zezati se sa APM-om i podešavanjima za 15 eura koliko košta cc3d ili naza stvarno nema poentu!
DA je nešto budućnost se slažem ali samo u varijantama koje su pošteno urađene a ne kvazi projekti za male novce koji posle koštaju bar kao 2 ozbiljna quada.
Danas 3D štampač posebno po Kini, Americi ima malo malo ko god hoće da se zeza. Isto je i za male lasere ili CNC mašine koje režu delove za frejmove. Pa otuda posebno iz Kine gomila pokušaja da vam se parice izvuku iz džepića....
Post by: mikijus on September 10, 2016, 08:39:56 PM
pa i ja to mislim nego ovo imam kuci dva full komada...a i nekako volim mision planer :)
gledam ove f3 ... kazem nemam iskustva sa trkacima evo kako mi koristimo fpv
https://www.youtube.com/watch?v=FyTLYe74NHY&index=2&list=PLw8Fb_iCyNIqSi-0rkRwBtzMju3ekMVD-
Post by: mikijus on September 20, 2016, 10:53:08 PM
https://youtu.be/fgJPerfHiqo
Post by: zloxi on September 21, 2016, 11:22:07 AM
Da si kao referentni mikro model naveo neki rejser do 60-70 grama bilo bi ok...
Frejmom 150 i 2-3S baterijom leteti po stanu = Kupi novi namestaj.
Frejmom 150 i 2-3S leteti po dvoristu = Moli Boga da komsijina macka spava.
Frejmom 150 i 2-3S leteti po parku = Podrzavanje bele kuge ubijanjem dece :D
Post by: mikijus on September 22, 2016, 11:35:46 AM
to i pokusavam da kazem :)
...evo stigle mi elise kolicne su u poredjenju da plastikanerima koje sam do sada korisio za zabavu  :)
https://www.facebook.com/photo.php?fbid=10154772348667345&set=a.74871192344.89181.785277344&type=3&theater&notif_t=like&notif_id=1474458837949615
Post by: zloxi on September 22, 2016, 11:49:16 AM
Te male propove je gotovo nemoguce unistiti  :)aplauz
Do sada sam zveknuo Graupnera sigurno 10 puta u drvo. 20 puta o pod, par puta je pojeo beton i jednom me zveknuo u vugla... Samo jedan prop je pukao do sada i to na pola tako da verujem da je bila greska u materijalu :D
Kad ti stize mikro? Ja sam 9.9 porucio neke delove preko banga i juce su stigli  oo))
Post by: mikijus on September 22, 2016, 05:38:36 PM
evo ga na carini nadam se od ponedeljka ...
nas par je narucilo ....vec sam smislio stazu po dvoristu i kuci :)
Post by: mikijus on September 26, 2016, 05:19:08 PM
napokon je stigao i radi sa mojim 9xr sa Fr sky modulom..... lako se namesta
https://www.facebook.com/photo.php?fbid=10154787660452345&set=a.74871192344.89181.785277344&type=3&theater
Post by: marko.jovanovic on September 27, 2016, 08:39:22 AM
Kad je već stigao srećno ti bilo junače.
Ali kao što narod naš kaže.
Od govana se pita ne pravi.
Nemoj misliti da vređam ali uverićeš se sam.
Ako ti je trebao mikroquad za FPV bolje da si kupio nanoqx blade.
Zaštićenost komponenti na ovom quadi nije baz na zavidnom nivou.
Post by: mikijus on September 27, 2016, 11:37:24 AM
Sad stvarno moram da te pitam letis li ti uopste...mislim daj neki video ili samo mracis po forumu ...
naravno da sam uzeo zastite za elise i pravim rolbar za antenu,a (to sam video na rcgroup-u)sto se tice vetra danas sam leteo po solidnim vetru na dunavu i moram da ti kazem da se ponasa mnogo ozbiljnije nego sto sam mogao i da pomislim....a veruj mi imam iskustva sa naj ozbiljnijim multicopterima...evo vidi cime sam se bavio :
http://helisangels.com/
Post by: marko.jovanovic on September 27, 2016, 12:02:44 PM
Kazaće ti se samo
Post by: mikijus on September 27, 2016, 12:54:26 PM
Nadam se da nece :)
https://www.facebook.com/photo.php?fbid=10154790945842345&set=a.74871192344.89181.785277344&type=3&theater
Post by: zloxi on September 27, 2016, 05:24:20 PM
Tooooooo... a sad pravo u park, mozes da ga picis bilo gde na 3x3 metra kad god ti dune... oo))  (yay)
i okaci neki video kad stignes  :mhm
https://youtu.be/_-LSvLOhrRk (https://youtu.be/_-LSvLOhrRk)
Post by: firebird on September 29, 2016, 06:18:54 PM
@mikijus, jel bilo problema na carini ili je prošlo kao igračka?
Zagolicala me spravica, taman mi za dvorištance ... mmmm
Post by: mikijus on September 29, 2016, 09:58:22 PM
dosao za dve nedelje carina nije postojala.... igracka :)
nego su mi vr d2 na carini 7 dana pa da izbacim neki video :)
Post by: mikijus on October 07, 2016, 09:44:53 PM
moram jos dosta da vezbam...  :)
ali ovo je sjajna igracka....svima je preporucujem
https://www.youtube.com/watch?v=fIV58fLqECo
Post by: zloxi on October 08, 2016, 04:58:47 PM
Sjajno, koji si to mod leteo? :)aplauz
Blagi problemi sa DVR-om od Eachine vr d2?
Post by: mikijus on October 08, 2016, 05:17:42 PM
angle mod dok ne naucim :)
da zeza dvr na VR D2 - black screen problem  ima na rcgroups preko 100 strana o tome ali kad letis to ne vidis na av1
i da bio je vetar i bolje ga podnosi nego ortakova tarantula koja se vidi na snimku
Post by: zloxi on October 08, 2016, 05:33:40 PM
Prijem slike je inace super  :)aplauz
Samo ga nagni napred i drzi pod gasom, sto brze letis to ce bolje slusati komande.
Par sati leta ti treba da dobijes osecaj... onda ces pozeleti brzo da predjes na acro  oo))
Post by: mikijus on October 08, 2016, 06:27:25 PM
evo jesam :)
nego je dvr los inace sam leteo 5 minuta ali samo ovaj deo moze da se gleda i to losiji deo leta :)
https://www.youtube.com/watch?v=YUbTfKlJ3f0
Post by: zloxi on October 08, 2016, 06:36:33 PM
 :)aplauz :)aplauz :)aplauz
Sve bolje i bolje  (res)
Post by: mikijus on October 09, 2016, 08:13:54 PM
https://www.youtube.com/watch?v=7xK2-kmaBN8
Post by: zloxi on October 10, 2016, 01:17:53 PM
 (<--) koliko drzi baterija?
Evo i ja da se pohvalim malopre mi stiglo...
(http://www.directupload.net/file/d/4504/a6wuqkwz_jpg.htm)
http://www.directupload.net/file/d/4504/a6wuqkwz_jpg.htm (http://www.directupload.net/file/d/4504/a6wuqkwz_jpg.htm)
Cekam jos prijemnik iz poljske  :'(
(http://www.directupload.net/file/d/4504/mb5md5ds_jpg.htm)
http://www.directupload.net/file/d/4504/mb5md5ds_jpg.htm (http://www.directupload.net/file/d/4504/mb5md5ds_jpg.htm)
Post by: mikijus on October 10, 2016, 01:30:22 PM
ovo je vec ozbiljno :)
ti sigurno neces imati dvr problem :)
Post by: zloxi on October 10, 2016, 01:36:46 PM
Fat Shark ima mnogo jadan DVR  :-[ ali je hdmi ulaz jako praktican za letenje sa emulatorom  :mhm
Post by: zloxi on October 11, 2016, 11:48:27 AM
Leteci limun stigao konacno  :)aplauz oo)) :)aplauz
(http://www.bilder-upload.eu/thumb/9c8560-1476177834.jpg)
http://www.bilder-upload.eu/show.php?file=9c8560-1476177834.jpg (http://www.bilder-upload.eu/show.php?file=9c8560-1476177834.jpg)
Post by: Asterix on October 11, 2016, 12:04:34 PM
Jel to planiras da sklapas et 160  :big smile
Post by: zloxi on October 11, 2016, 12:17:43 PM
 mmmm Stoji mi neki gr12l pa sam mislio da ga zbudzim direktno na Kiss FC  :)aplauz
Post by: gerotmf on October 12, 2016, 12:35:41 AM
A evo i mojeg frankensteina :) frame 120mm sa banggooda, motori 8mm od syma, propovi od ladybird, kontroler od razlupanog eachine x4 3d, baterije 650mAh od syma x5c, upucan silverxxx firmware za acro mod, malo gumica da drže bateriju  .. još samo da vidim gde i kako da prikačim kamericu i eto fpv makine  (<--)
Sve to ganja deviationtx devo 7e sa modom nrf24l01, quadič je veeeeoooma stabilan a ima i snagu/brzinu- dok ne stavim gore kameru  mmmm, morao sam da podesim expo na 40% da bi mogao da ga kontrolišem
Isto to moze da se smesti i na 90mm frame sa banggooda, ali mi fali još jedan kontroler - naruceni su od mini h8 pa cu da vidim sa njima sta moze da se napravi.
Post by: zloxi on October 12, 2016, 08:43:30 PM
 ") :)aplauz Bas si ga zbudzio
Post by: mikijus on October 12, 2016, 09:33:46 PM
pogledajte ovu grupu na fejsu :)
https://www.facebook.com/groups/1426753670674919/
ima dosta zanimljivih stvari za nas  koji volimo micro fpv zujalice   ;)
i da moram malo da se osvrnem na forumase koji sve znaju a malo lete...ovo je odlican koncept !!!
u poslednjih mesec dana pojavilo se desetak modela na foru qx90,qx95,qe100,qe110,JJRC JJPRO - T1 95mm FPV Racing .....
i nebrojeno kucnih varijanti sa 3d stampaca....inace novi f3 evo sada moze  da zakaci i 6 motora....
i da danas je kisa i vetar a ja ceo dan letim fpv po kuci ...svakoga dana u svakom pogledu....  :)
Post by: mikijus on October 18, 2016, 04:19:49 PM
http://fpv-racer-bauen.de/fpv-homeracer-vergleich/
Post by: lazar89nis on October 18, 2016, 05:21:10 PM
thx za link. gledam ja sebi da kupim za rodjendan jedan posto mi je kolega izgubio hubson x4 :D
mislim da cu da uzmem qx95
Post by: mikijus on October 19, 2016, 07:48:23 PM
https://www.youtube.com/watch?v=mKkFcYFO0jU&list=PLw8Fb_iCyNIqSi-0rkRwBtzMju3ekMVD-&index=15
Post by: gerotmf on October 30, 2016, 11:26:45 AM
A evo i 90mm frame je poleteo, eachine h8 mini blue board receiver, 8x20mm motori, 55mm propovi i 350mAh baterije, acro/level mode, leti ludnica :)
Post by: lazar89nis on November 15, 2016, 03:01:26 AM
Konacno mi je stigo qx95 :)  (<--)
(http://i270.photobucket.com/albums/jj109/lazardj/6EBA28CB-814F-456D-B90E-674E57164735.jpg)
Post by: marko.jovanovic on November 15, 2016, 07:58:27 AM
Zašto tu postoji zaštita za antenu?
Na mnogo većim i ozbiljnijim quad-ovima nema zaštite a radi se o mnog većim  brzinama i silama udara pa antene ne otpadaju baš tako lako.
Takođe zaštita za motore meni ovde deluje više šminke radi jer povećava polugu pri udaru motora a samim tim povećava verovatnoću da se pre iščupa njegovo ležište dole, uništi ili otkinu žice koje idu do motora..
Na nanoqx-u ili inductrix-u je mnogo sretnije rešenje napraljeno za zaštitu
Post by: lazar89nis on November 15, 2016, 10:59:06 AM
zato sto planiram da ga letim po kuci, antena se drzi direkno na VTX pa se lako cupa.
nista nije sminka na istom ali dobro :) nisam ni mislio da ti nemas misljenje :D
Post by: mikijus on November 15, 2016, 05:52:39 PM
bravo ,,,, :)
kako si napravio zastitu za antenu....ja cekam novu kameru , posto sam proslu sprzio....
ovu :
http://www.banggood.com/Eachine-AIO-5_8G-40CH-25MW-VTX-800TVL-13-Cmos-FPV-Camera-Upgraded-for-QX90-QX95-Racing-Quadcopter-p-1086282.html?rmmds=myorder
Post by: lazar89nis on November 15, 2016, 05:56:30 PM
skinuo sam neki model koji mi je delovalo da je dobro uradjen ali nisam procitao komentare :) odstampao na 3d stampacu i shvatio da razmera nije ni priblizno dobra :D
onda sam uzeo skalper i recnuo je na dva mesta i shvatio da je ovako jos bolje :D
ako si iz nisa mogu da ti odstampam
Gledao sam i ja tu kamericu. juce povezem quad kad ono mrlje na sve strane :( i onda uzmem da istrazujem i nadjem da ako umotam kamericu u izolir da ce sve biti ok. uradim to i ona radi super :) mada sam trazio zameni od banggood-a posto je ova felericna
Post by: marko.jovanovic on November 15, 2016, 08:06:53 PM
A smejali ste se meni kada sam rekao da će početi da se menjaju delovi pa će biti skuplja pita od tepsije... 10 po deset, 25 po 25 eura....
Da li su antene svima otpadale ili ti to onako na svoju ruku?
Kažem ti znaš kako se padalo sa mnogo većim quadom  gde antena stoji direktno zavrnuta za prijmnik koji je samo fiksiran na frejm pa ništa nije otpalo.
Post by: lazar89nis on November 15, 2016, 08:13:54 PM
zavisi kako vozis i gde. nije na moju ruku taj bumper. to je preporuka sa foruma od ljudi koji leta u kuci. ja radim preko dana pa mi ostaje samo uvece da se zezam sto znaci letenje po kuci. taj deo je tezak svega 1 gram a moze da mi spasi antenu. nema razloga da ne bude tu :D
znam i sam da nema zastite za antene za mini quad. ni ja na mom nemam. ali ako vec iskusniji od mene preporucuju nista me ne kosta da je stavim ;)
Post by: marko.jovanovic on November 15, 2016, 11:54:21 PM
Ne znam šta da ti kažem.
Taj quad meni jako loše kostrukcijski izgleada i kao da ga je neko kostruisao namerno da bi se posle delovi prodavali.
Ako je quad 50 eura a samo kamera 25 tu onda nisu čista posla u startu.
Prvo su kameru isturili napred  bez ikakve moguće zaštite kako bi se najpre izlomila...
Frejm kao da je okrenut namerno naopačke pa nazad imate ruke frejma koje su pod uglom i štite ništa a napred ravne.
Drugo kažem ti ako već imaš 3d štampač po meni razmisli da konstrukcijski malo spustiš te zaštite za propelere jer tako kako stoje na motorima imaju jako velike poluge koje koje  prenose silu udarca direktno na koren motora i ruke frejma.
Razmili prvo šta ti je jeftinije da zameniš izlomljen propeler ili da menjaš motor i kupuješ frejm...
Treče na tako mali quad 5 grama nije mala stvar.  To ti je 10% njegove ukupne mase.
5 grama sam rekao a to je izgleda čak i 10 sa ovim zaštitama.
Ja bih čak razmislio da okrenem sve na drugu stranu jer su nazad ruke pod uglom a ima i onaj deo frejma koji je izbočen.
KOliko toliko bi zaštitio kameru i antenu pri direktnom čeonom sudaru a ne bi ti trebalo dodavanje nepotrebnog balasta.
Možda to i ne može da se uradi lako bez bušenja i karabudženja ali sve se može uraditi.
Najgore je što sva ta oprema nama nije tako lako dostupna pa kada recimo uzmeš takav quad zarad letenja po kući na zimu i rasturiš ga u prvim letovima treba čekati mesec dana da kinezi ponovo pošalju delove.
Blade nano qx kod mene je zgažen, padao pojma nema koliko, jednom mi je pukao propeler i jednom sam zamenio za skoro 2 godine 4 motora jer su uredno od korišćenja potrošene četkice.  Sada sam naručio kameru pa će da se leti fpv po lošem vremenu.
Jeste da nije baš toliko brz kao taj jer je slabiji ali za po kući je i više nego dovoljan, u nedostatku inducrtrix-a
Post by: marko.jovanovic on November 16, 2016, 09:12:42 AM
Interesantan video za one koji vole ove mikro spravice.
https://www.youtube.com/watch?v=28aPXUUcQUw
Post by: lazar89nis on November 17, 2016, 11:28:01 PM
jedan od prvih letova :) nisam jos stigo da letim napolju  (<--)
https://www.youtube.com/watch?v=klIzUyc2K7s
Post by: Asterix on November 17, 2016, 11:54:04 PM
 :)aplauz Dobro si uvezbao, a nema ni malo gubljenja video signala u drugoj sobi.
Post by: lazar89nis on November 17, 2016, 11:55:54 PM
ej moram da testiram na maloj vecoj daljini :) probao sam da stavim quad u jednu sobu a da se popnem da drugi sprat sa nocarima i jos uvek sam imao signal :) samo me jebe to sto imam tajmer na stepenistu pa ce da mi se gasi stalno svetlo :P
ovo jes nije bio acro mod. ali planiram skroz da predjem na njega :) zato sam i uzeo ovog malog da vezbam
inace zastite su se pokazele kao super ideja. uspeo sam da polomim zastitu za antenu, nakon toga pao jos jednom i antena pocela da se krivi. sad sam odstampao jacu zastitu koja ce ja mislim duze da traje dok se ucim. 1 gram teza ali dok se ucim nek stiti antenu i quad :)
Post by: gerotmf on November 20, 2016, 05:15:20 PM
Evo mali dobio i fpv, morao sam da nabavim polulu dc-dc booster da ispravi napajanje za kamericu i predajnik, posto cim se motori upale ode slika. Moram jos da nekako snimim video (cekam pvr iz kine :). Leti super, mozda cak i prebrzo za letenje unutra :)
Kamera i antena su malo povuceni unutra, pa i kad padne, padne na propove ili bateriju - sto mi se ne svidja ali ne vidim nekog boljeg resenja a da ne utice previse na tezinu.
Inače za po stanu jurcati ne vidim neke prevelike potrebe za nekom drugom antenom, i ovako mi vuče lepo sliku kroz 2 (dosta tanka) betonska zida (penzionerski stil voznje, nema flipova i ostalog .. ionako nema nekog mesta po stanu).
Za 40tak dolara nema bolje zabave :)
Post by: gerotmf on November 26, 2016, 03:33:45 PM
Ako neko sastavlja svoj mini fpv i ima problema sa smetnjama na slici - tj gubitak slike - kad motori prorade, našao sam (uz polulu koji je dosta skuplji) i kinesku verziju dc-dc buck/boostera koji radi (u pola cene naravno :). Evo linka https://www.aliexpress.com/item/2pcs-DC-DC-Auto-Boost-Buck-Step-Up-Step-Down-Converter-Module-Voltage-Board-for-LED/32757288766.html?spm=2114.13010608.0.0.e2AIEb (https://www.aliexpress.com/item/2pcs-DC-DC-Auto-Boost-Buck-Step-Up-Step-Down-Converter-Module-Voltage-Board-for-LED/32757288766.html?spm=2114.13010608.0.0.e2AIEb). Isprobano na syma x5c.
Post by: marko.jovanovic on November 26, 2016, 04:11:41 PM
LC filter i sami možete napraviti.
TReba vam samo dve komponente a to je jedan kondenzator od 16V i 100mikroF i jedna zavojnica od 300 mikroH
Sve to možete naći po starim radio prijemnicima ili nekim starim pokvarenim telefonima recimo...
Suština je da se napon ispravi na kondenzatoru a da se filtriraju loše frekvencije pomoću zavojnice.
Evo i videa koji objašnjava kako se to radi
https://www.youtube.com/watch?v=ziCjz5K9h4I
Naravno sve to može u manjem pakovanju sa manjim komponentama. Malo izguglajte i naćiete vrlo lako oznake za zavojnice...
evo vam i slika kako izgledaju male zavojnice u smb varijanti pa ih možete potražiti po starim elektronskim uređajima koji vam stoje ili su pokvareni
https://www.google.rs/search?q=smd+inductor+100uh&espv=2&biw=1366&bih=638&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjZvf_X2sbQAhUmLZoKHUXwBZ8Q_AUIBigB&dpr=1
Post by: gerotmf on November 26, 2016, 05:11:02 PM
Probao to, ne radi brate .. imam i sa manjim i sa večim feritima, ručno navijenim na onaj zeleni ring, smd verzijama zbog veličine,  elektrolitima, tantalum kondenzatorima, keramikom, schottky diodoma za prevenciju pražnjenja nazad na motore .. svašta .. jednostavno ne radi. Pad napona u špicama na dole na 1s bateriji je prevelik (izmerio sam pad na 3.1V) . Možda bi radilo sa nekim kvalitetnijim video predajnicima (boljim naponskim delom), valjda imersion radi super, ali ja imam jeftine boscam module i jeftinu banggood kamericu. Ovo radi, zato sam i postovo a probao sam dosta toga, od onih 1s na usb 5v adaptera, pa do lc filtera kao sto si ti poslao link.
Post by: lazar89nis on November 26, 2016, 05:15:58 PM
evo ga prvi let napolju :) jos uvek cekam na baterije pa zbog toga slabo letim :(
https://www.youtube.com/watch?v=IoBjhd2J5So
Post by: gerotmf on November 26, 2016, 06:07:29 PM
super :) ja bi trebao neke prop guardove da nabavim polako mi nestaje propova :)
Post by: marko.jovanovic on November 26, 2016, 06:11:22 PM
Na lazarovom snimku deluje sve ok ali on ima onu kameru sa predajnikom na sebi koja ide uz taj quad.
Ti vidim da imaš onaj uradi sam modul tj predajnik.
Koliko sam uspeo da pročitam na netu o njemu, kod nekoga to radi a kod nekoga ne.
Ja sam odustao od kupovine tih varijanti baš iz tog razloga ako, možda i valjda...
LC filteri ne pomažu kod gubitka slike nego samo kod horizontalnih smetnji tj linija koje se javljaju zbog šumova koje prave esc-ovi i to lc filter dobro odradi. Kod gubitka slike problem je najverovatnije kao što si već i rekao u velikim padovima npona što taj pololuloluolou ili kako se već zove dobro odrađuje.
Bilo kako bilo dobor je da imaš rešenje.
Nekda su ti moduli bili skoro džaba a sada koliko vidim jeftinije je kupiti gotov nego njih.
Da li zato što ih niko ne kupuje ili šta već ali vidim da su preskupi..
Kamera tu tebi nije problem jer nije ništa ni bolja ni lošija od ove koja postoji na lazarovom i ostalim quadovima.
cmos 600 tvl i to je to.  ()-()
Post by: gerotmf on November 27, 2016, 09:25:28 AM
pololu ti je ovo
https://www.pololu.com/product/2123
zanimljiv site za elektro hobiste, i dosta kvalitetno uradjeni moduli .. pogledaj razliku u veličini izmedju njihovoh dc-dc buck/boostera i kineskog
Post by: marko.jovanovic on November 27, 2016, 09:38:48 AM
Znam šta je pololu video sam recenzije kada su izbacili to još davnih dana samo se zezam što se tiče imena.
Svakako dobra svar koja malo košta
Svakako lepo je što si rešio svoj problem i podelio to sa ostacima...
Ja imam jedan buster sa HK-a tj sa 1s na 2s varijantu ali ovo je bolje jer drži 5V bilo da je veći ili manji ulazni napon.
Post by: mikijus on November 29, 2016, 02:34:14 PM
https://www.youtube.com/watch?v=WDXd3XRnEag
krenula je zima a leteti se mora :)
...makar i po sobi...
cekajuci nove motore .... i lepse vreme :)
Post by: marko.jovanovic on November 29, 2016, 04:04:47 PM
Okanite se letenja u stabilizator modu ili kako se već zove.
Nikada nećete naučiti.
Akro mod iako deluje zastrašujuće za početnike ipak dozvoljava da vi sami kontrolištete letelicu a ne ona vas.
Preporučujem prvo letenje u akro modu na nekoj povećoj površini čisto da se rastera strah od njega posle te modove koje koristite za stabilizaciju neće vam pasti na pamet da uključite...
Post by: mikijus on November 29, 2016, 04:33:40 PM
po sobi ? ..... ne pada mi na pamet :)
Post by: marko.jovanovic on November 29, 2016, 05:44:03 PM
U akro modu možeš leteti u bilo kojoj veličini prostora. Akro mod nije mod u kome moraš da letiš sa rolovima, brzim letenjem, driftovanje...
U opšte veruj mi mnogo je bolja kotrola letelice i niko tebe ne tera da dodaješ gas do kraja. Veruj mi u akro modu možeš leteti i sporo.
Stvar je u tome samo što je kotrola u tvojim rukama a ne u rukama senzora.
Svi smo u početku tako razmišljali tipa ma da nema šanse da letim u akro modu ako nije veliki prostor...
Veruj mi jednom kada se oslobodiš prostor je nebitan.
Post by: mikijus on November 29, 2016, 11:38:56 PM
probacu cim ga flesujem sa betaflight-om :)
Post by: marko.jovanovic on December 03, 2016, 07:09:28 PM
Moja micro FPV mašina
(https://s13.postimg.org/gwh5d3qdv/20161203_182617.jpg) (https://postimg.org/image/gwh5d3qdv/)
(https://s13.postimg.org/ku4f2id77/20161203_182626.jpg) (https://postimg.org/image/ku4f2id77/)
Ono što me je jako prijatno iznenadilo jeste kvalitet slike na kameri iako je cmos senzor.
Slika je jednako dobra i u kući i u mračnim prostorijama kao i napolju. Boje fantastične.
Kamera je uzeta na HK-u
Svaka preporuka.
Post by: gerotmf on December 03, 2016, 10:28:52 PM
Super, jel su to 7mm motori? mogu da ponesu kameru i sve? koja baterija?
Post by: marko.jovanovic on December 04, 2016, 12:25:47 AM
Motori su 6mm ali su sa micro motor ovi
http://micro-motor-warehouse.com/collections/all-motors/products/cl-0615-19
Takođe sam naručio frejm i propelere za inductrix a merkam i f3evo
https://www.aliexpress.com/item/Eachine-F3-EVO-Brushed-ACRO-Flight-Control-Board-DSM2-For-Inductrix-Tiny-Whoop-Eachine-E010/32737310190.html?spm=2114.13010208.99999999.264.qsZqT0
Sa ovim baterijama kada budu na stanju biće UHUHU
http://www.mylipo.de/Lipo-205mAh-37V-25C-50C-HV-435V-spezial-Stecker-PWConnector-TinyWhoop
TRebalo bi da izgleda ovako
https://www.youtube.com/watch?v=W25Dhksj0Yw
Post by: gerotmf on December 04, 2016, 01:04:42 PM
prijatelj vozi na tatoo i isto su super, ali nema na lageru, ne znam kakve su ove
http://www.lipo.si/izdelek/G-Y80100510/brainergy-220mah-8-kos-inductrix
Post by: marko.jovanovic on December 04, 2016, 01:57:26 PM
Generalno ima ovde lepih marki koliko vidim.
Ja sam sa ovim što letim zadovoljan.
Jedino je nanoqx malo većih gabarita pa nije baš zgodno kada su neki manji prostori u pitanju.
Zato i merkam inductrix jer je fantastičan što se tiče veličine i upravljivosti.
A kada se uzme kako treba oprema može da parira vrlo lepo i većoj braći.
Svakako zabava za zimske dane po kući. JOš kada priključiš na tv od 43 inča bude zezanje.
Gledao sam recenzije za inductrix fpv i ova kamer koju ja imam je 3 u čelo za onu koja je na originalnom inductrix-u.
Vrlo lepo može da se koristi i na većim mašinama jer može lako da se spoji na veće predajnike.
A malena je tako da je možeš postaviti gde hoćeš.
Post by: gerotmf on December 04, 2016, 08:08:18 PM
Taj je uvoznik za gensace ovde a i glavni kod nas za fpv, organizuje takmičenja u 250 klasi a sad po novome i za tiny whoop klasu (u dvorani). Nisam još bio da vidim kako izgleda, tako da nemam iskustva iz prve ruke, valjda cak i strimuje preko FB.
Ja sam naručio [link]http://www.banggood.com/Eachine-TX02-Super-Mini-AIO-5_8G-40CH-200mW-VTX-600TVL-14-Cmos-FPV-Camera-p-1088368.html[/link] kamericu, nadam se samo da neče imati problema sa brushed motorima...  mmmm
Post by: marko.jovanovic on December 04, 2016, 09:20:41 PM
Nećeš istu tu kameru imam i ja samo sam je dobio sa plastičnom zaštitom koju sam naravno skinuo.
Videćeš i oduševićeš se kvalitetom snimka.
Generalno trenutno postoji par proizvođača komponenata i senzora i skoro sve kamere se sada baziraju na jednim te istim senzorima kao što je to slučaj sa recimo legendarnom sony super had II.
Ostalo su samo štampanje logoa firmi koje ih sklope da budu kamere....
Ono što je dobro jeste da je sve to modularno pa tako može da se iskoristi kameru za neku drugu svrhu sa jačim predajnikom...
Jedva čekam da stignu delovi za whoop-a
Post by: mikijus on December 06, 2016, 07:56:47 PM
ja sam danas uspeo da slomim i drugi ram za qx90...stvarno je los narucio sam ovaj da probam
http://www.banggood.com/Eachine-E100-100mm-Carbon-Fiber-DIY-Micro-FPV-RC-Quadcopter-Frame-Support-720820-Coreless-Motor-p-1074771.html?rmmds=myorder
sa ovim elisama
http://www.ebay.com/itm/291700158936
izgleda da cu morati sam da ga pravim od ovoga
https://hobbyking.com/en_us/woven-carbon-fiber-sheet-300x100-1-5mm-thick.html?gclid=CP-Wm52U4NACFZQW0wod7cMFjw
Post by: marko.jovanovic on December 06, 2016, 08:20:18 PM
Joj kako ste me napadali kada sam rekao da je to golo da ne kažem šta.
A sada malo malo se kupuju i dokupljuju ramovi, kamere....
Nemojte da se ljutite ali treba malo stati na loptu i ne verovati samo raznoraznim reklamama i recenzijama ljudi kojie ti isti prodavci sponzorišu da lome po 3 komada dnevno samo da se pojavljuju sa pozitivnim kritikama na YT-u.
Ja imam blade nano qx evo već drugu godinu. Promenio sam samo set motora (jer motori sa četkicama pogotovo ti što se vrte sa 19000 KV nisu večni) i dokupio nove propelere mada mi nijedan nikada nije pukao nego se izlizali od čukanja. Jedam ram sam kupio ali samo zato što mi je klinac stao na njega pa ni on nije pukao nego ze razdvojila zaštita koja štiti motore. Ram je od plastike savitljive toliko da nema šanse da nešto pukne pri letu i sudaranju.
Vozio se danima kada je došao, kada god mi dune letim sa njim, sada je kamera stigla pa svaki dan ispraznim 9 baterija po kući.
Ram za inductrix naručujem isključivo zato što je manjih dimenzija pa može lakše da se provlači u manjim sredinama. Ram inače košta 2 eura pa i da se polomi nikakva šteta, ali vidim da nisu baš tako lomljivi. Propeleri dobro zaštićeni, a leti za sve novce.
Nisam vam ono govorio zato što volim da mračim nego što sam se nalomio raznoraznih frejmova, motora, esc-ova.... na raznoraznim jeftinim varijantama pa čisto da neko ne plati tako skupu školu jer dobro znamo u kakvoj zemlji živimo i koliko nam je sve skupo, a naročito ovaj hobi koji je skuplji od heroinske zavisnosti.
Bar sam naučio da kada kupujem jeftinu stvar da 3X razmilim da li će zaista da izađe jeftino posle.
Karbon je jako dobar materijal ali ima jednu manu a to je krtost i loše praštanje naglih pregiba, rupa i otvora i obično puca na tim slabim mestima. VEćinom ti kineski frejmovi izuzev par koji su sa razlogom  skuplji, napravljeni upravo tako da moraš posle da dokupljuješ više puta. Kinezi zgrnuše lovu na jeftinoj robi koja sva do jedne uvek ima slabu tačku kako bi se kupila vrlo brzo ponovo. Da li je to slab materijal ili loša konstrukcija, loši elektronski element...
U svakom slučaju krivo mi je što ste platili školu kao i ja..
Svako dobro i  ()-() (<--)
Post by: mikijus on December 06, 2016, 08:41:46 PM
oba su pukla na istom mestu...spoj ruke i lezista za motor
Post by: deki-ns on December 06, 2016, 10:45:13 PM
ja sam danas poručio delove za ovu spravicu Tiny Whoop https://www.youtube.com/watch?v=k8IEXKtheXo
Postaje hladno za letenje napolju  lol
Post by: marko.jovanovic on December 07, 2016, 12:34:51 AM
Imaš na ovom sajtu motore. http://micro-motor-warehouse.com/
 Jeste da su malo skuplji ali vrede.
Baterije takođe.
A najače od svega je što ima i f3 fc koji može na betaflight
Kada sve to izračunaš neće da izađe ispod 100 eurića ali zato ide ko raketa i može svašta sa njim da se radi i napolju.
Postavio sam linkove par postova gore.
Ja sam poručio delove a fc ću da iskoristim sa nanoqx-a pa da vidim da li će i kako leteti.
Ako ne onda mi ne gine f3.
Post by: lazar89nis on December 07, 2016, 01:04:39 AM
kako si uspeo da slomis dva rama? ja sam padao po betonu i po sobi sa mojim qx95 i nisam imao problem. udario sam cak i jednom u kapiju, par puta u granu... :)
ja imam spremne neke stampane ramove ako ovaj slucajno pukne
Post by: mikijus on December 07, 2016, 09:51:06 AM
stvar je u talentu :)
a i ovaj drugi sto mi je stigao izgledao je mekse od oreginala...
nego nadam se da cu od ovoga da napravim 8 komada :)
http://www.ebay.com/itm/400-250-1mm-Carbon-Fiber-Plate-Panel-Sheet-3K-Plain-Weave-Gloss-Corrosion-Resist-/262690333117?hash=item3d299061bd:g:XLoAAOSw44BYDzO9
Post by: mikijus on December 07, 2016, 06:09:37 PM
narucio sam i ovaj
http://www.ebay.com/itm/322181968044
Post by: gerotmf on December 11, 2016, 08:05:44 PM
Ovde koriste neki E6000 lepak da ojačaju frame, važi i za e010 frame kao i original inductrix. Oba pucaju kod nosača motora ... inače evo jedan link na live fpv stream sa današnjeg takmičenja :)
https://www.youtube.com/watch?v=3EQs_s8hAHw&feature=youtu.be
Antene za prijem su mi bila iza takmičara pa se malo gubi slika ..
Post by: marko.jovanovic on December 11, 2016, 09:46:06 PM
Koliko samo malo kvadrata treba za sreću  :big smile
da li je to ovaj lepak?
https://www.amazon.co.uk/Eclectic-E6000-Multipurpose-Adhesive-Pkg-18oz/dp/B00CB3BZBW/ref=sr_1_3/255-4352565-0453814?ie=UTF8&qid=1481489176&sr=8-3&keywords=e6000+craft+adhesive
Post by: gerotmf on December 13, 2016, 12:31:51 AM
Izgleda mi kao taj ...
http://www.lipo.si/izdelek/G-E6000/lepilo-e6000-inductrix
baš sam se setio da mi je kolega zalepio motor 8.5mm na carbon sa time juče. i sad sam proverio, drži pošteno :)
evo još jedan snimak od Alana .. ovaj put sa njegovog DVR
https://www.youtube.com/watch?v=bAwJFzSmFaI&feature=youtu.be
leti sa inductrix frame, f3 kontroler, 17kkV motori iz mmw, mylipo.de HV baterije, 0.8mm bullet konektori za struju.
A ovaj snimak je od njegove rakete, 19kkV motori, odrezana elisa na 2 kraka .. i ne znam ostale specifikacije
https://www.youtube.com/watch?v=8hnuxXp4j4w&feature=share
Post by: marko.jovanovic on December 13, 2016, 07:39:05 AM
Lepo.
Primetio sam da ljudi režu propelere  na 2 kraka pa jel ima to nekog poboljšanja na motorima sa nižim kv brojem recimo 16000 ili recimo 14000? Takođe da li poznaješ nekog ko vozi onaj aluminijumski frejm odnosno pola aluminijum pola karbon i da li je bilo lomova karbonskog dela?
Jedva čekam da mi stignu delovi. Naručio sam i f3 fc beecore jer sam na bangood-u naleteo na neko sniženje.
Post by: gerotmf on December 13, 2016, 10:26:29 AM
Ovde svi gledaju na svaki gram, pa taj frame carbon/alu ne dolazi u obzir, najbolje se pokazao original inductrix pošto je i najlakši.
Spremamo se i na vanjske trke - kad zatopli, tu več dolazi u obzir jači i teži 90mm ili 120 mm frame sa 8.5mm motorima.
Leteli smo i po dvorani sa mojim frankenstein 90mm banggood frameom sa fpv kamerom - več sam postovao slike ovde, i ubrzo ti postane dvorana premala, zbog težine quada sa fpv i baterijom od 250 mAh ima veliku inerciju i moraš puno ranije da počneš da skrečeš.
Što se tiče 2 kraka, quad malo izgubi na stabilnosti a pridobije na dužini leta, ali to nije uopšte bitno kao što vidiš trka traje minutu/dve. Ja lično nisam probao sa 2 kraka, pošto još čekam neke malo jače motore - naručio sam chioli 0615 i neke insane od inductrixa  .. možda su čak jedno te isto :) Valjda su se najbolje pokazali MMW 17kkV motori ali sam to saznao tek kad sam več naručio druge.
Kod svih jačih/bržih motora se quad prvih 15-20tak sekundi trese malo više zbog nemogučnosti nameštanja PID-ova na originalnom FC, posle se umiri i sve ide ok.
Post by: marko.jovanovic on December 13, 2016, 04:49:10 PM
Pa vidi ti insane motori su 19000 KV i stvarno su INSANE ako su to ti.
Ja ih imam na blade nanoqx-u i leti kao raketa.
A industrix će da leti kao svetlost.
Za te motore stvarno treba odseći po dva kraka koliko sam video na netu jer može da se desi da nešto izgori.
A kada na te motore dodaš i LIHV baterije one na 4.35V to onda mora da je umobolno.
Veruj mi da sa takvim setup-om neće ti padati na pamet da uzimaš veći quad koliko ovo dobro ide.
Mana takvog setup-a je samo što trajanje baterije zna da koliko sam video bude oko 1 minut a i motori sa većim KV brojem imaju daleko manji vek trajanja od ovih normalnijih.
Ja sam poručio sa bangood-a cl 615 sa 59000rpm to je negde oko 16000 KV pa će mo da vidimo.
Što se tiče pid-ova zato sam i naručio beecore f3...
Nestrpljiv sam da stigne mmmm
MOžda sam ovo i postavljao ali ovo je brzina sa 14000 KV
https://www.youtube.com/watch?v=W25Dhksj0Yw&t=13s
Post by: gerotmf on December 14, 2016, 09:57:35 AM
Danas sam poručio chioli 65000 rpm iz 'ameriku' ;)  (17500kV) 12.99$ set i 8$ poštarina za 2 seta .. pa da vidimo. Kad si več pomenuo karbon, primetio sam da koriste i tanke paličice za fixiranje motora, evo ovako
(https://scontent-vie1-1.xx.fbcdn.net/v/t1.0-9/14956480_10202004024659910_9113548769889645810_n.jpg?oh=75c41ee3a46bb2f6c39b1daace4545df&oe=58ECD131)
kao i 0.8mm bullete za napajanje, ništa ti ne koristi baterija koja može od sebe da da 9A ako je original konektor na njoj projektovan za max 1A.
taj video sam več video, to je rambo whoop, 19kkv motori i HV baterija .. ovde je spisak
[link]https://micro-motor-warehouse.com/collections/rambo-whoop[/link]
Post by: lazar89nis on December 20, 2016, 09:07:33 PM
Spreman za let :) Hvala RCSrbija  (pijemo)  (<--)
(http://i270.photobucket.com/albums/jj109/lazardj/C604A637-DBA4-4D71-9468-27EFEEE39767.jpg~original) (http://s270.photobucket.com/user/lazardj/media/C604A637-DBA4-4D71-9468-27EFEEE39767.jpg.html)
Post by: gerotmf on December 20, 2016, 11:15:36 PM
lepo, koji su to motori?
Post by: lazar89nis on December 20, 2016, 11:19:34 PM
stock qx95. nisam nista menjao. za sada super leti i sluzi mi za ucenje acro moda. samo sam mu stavio zastite za antenu i propelere posto ga lupam dosta dok ucim :D
Post by: marko.jovanovic on December 20, 2016, 11:29:10 PM
Povelik je to quad za po kući.
Inductrix je idealan.
Ja vozim blade nano qx koji je čini mi se 70 mm diagonala pa opet nije da ne može da se leti nego oseti se da ipak nije za neku fpv jurnjavu kroz male prostore. Ali dok ne stignu delovi zadovoljan sam sa ovim što imam.
Post by: lazar89nis on December 20, 2016, 11:31:00 PM
letim ja po dvoristu vikendom :) uskoro cu da napravim kapije za letenje :)
Post by: marko.jovanovic on December 21, 2016, 04:13:05 PM
Oni dugački baloni kod kineza rade posao za kapije savršeno a i kada naletiš na njega nema štete na quadu osim na balonu....
Post by: gerotmf on December 22, 2016, 03:45:00 PM
Stiglo na lager ...  (yay)
Post by: marko.jovanovic on December 22, 2016, 07:55:20 PM
http://www.banggood.com/Eachine-TX02-Super-Mini-AIO-5_8G-40CH-200mW-VTX-600TVL-14-Cmos-FPV-Camera-p-1088368.html?rmmds=search
Ovo je džaba.
Post by: gerotmf on December 22, 2016, 11:00:47 PM
Več kupljeno.. :)
Več je 14tog stigla u zemlju.. ali izgleda čeka na carini...   oo))
Post by: deki-ns on December 23, 2016, 07:56:37 PM
Stigla i moja spravica  oo))
Post by: marko.jovanovic on December 23, 2016, 08:29:29 PM
A blago tebi brate.
Meni delovi nikako da stignu.
Naručio sam svašta nešto i sve stoji kod J. carinika odavno.
Svaki ponedeljak po jedan paketić dobijem a trebalo je do sada da stigne sve.
Ladno sam za 6 dana dobio iz Kine žice za tensike rekete koje sam poručio kolegi a moje koje je poručeno pre mesec i više stoji i čeka da se smiluju.
Izgleda su praznici pa im se ne radi
Da nam se nealetiš sa tim ove zime...
Kako ide jesi li probao?
Vidim da imaš punjač za parelelno punjenje tih malih baterija.
Moj save ti je da ih puniš redno ako ikako možeš.
Iz razloga što si siguran da svaka baterija je napunjena koliko treba ovako paralelno jedna može da se prepuni a jedna da ostane prazna. Meni se dešavalo to dok nisam počeo da punim paralelno (što ne važi za baterije većeg S broja jer one imaju i balans kablove pa nema tih problema)
Sa slike ne vidim baš dobro ti si poručio onaj eachine e10 i kameru jel tako?
Ja imam spektruma pa sam morao da naručim posebno sve
Post by: brankelot on December 24, 2016, 12:50:18 AM
A reci mi koja je to spravica ?
Post by: deki-ns on December 24, 2016, 03:25:11 PM
To je tiny whoop.
Leti jako lepo.Odusevljavam se sa VTX-om, neverovatno kako dobro probija kroz prepreke i kakv domet ima.
Post by: deki-ns on December 24, 2016, 03:38:51 PM
A evo i prvog leta  :_D
https://www.youtube.com/watch?v=6H-vKDKfmpk
Post by: marko.jovanovic on December 24, 2016, 04:31:35 PM
Skoro se nisam bolje nasmejao.  lol :hehe :_D
Ala mu je pokazao svaka mu čast.
Jel otišlo nešto?
Videćeš kada malo uđeš u štos samo sa skontavanjem granica na slici vrlo dobro zezanje.
Posle oni dugački baloni od kojih se prave razne figure uvrtanjem oni mogu da posluže kao kapije i prolazi....
Adrenalinski skoro da može da zameni pravi race quad.
Post by: marko.jovanovic on December 25, 2016, 06:38:46 PM
Ovo obećava ali ne u ovoj varijanti nego sa nekim karbon frejmom 90mm ozbiljnijim ili neka alu karbon verzija kao što ima za thiny whoop-a (setup je vrlo zanimljiv).
Ali za letenje po dvorištu.
https://www.youtube.com/watch?v=tR2Ja4h9v3U&t=115s
Post by: gerotmf on December 25, 2016, 11:50:17 PM
Več se spremam :)
1104 motorčiči stigli .. u poredjenju sa xt60 konektorom  :_D
Post by: marko.jovanovic on December 27, 2016, 09:48:10 PM
Evo da i ja podelim moje radosti.
Od nedavno su mi stari motori počeli da crkavaju uzeti na micro-motor-warehouse.com
Imao sam one insane one sa 19.000 i ove sa 17.000
Insane su baš insane bar na  blade nanoqx-u i mislim da su više onako preterivanje zarad brzog adrenalina a ne za neko letenje sa uživanjem jer jako brzo troše baterije.
ovi od 17.000 su nedavno utihnuli pa sam na vremem naručio sa aliexpress-a cl 615 59000 RPM ili ti 16.000
Koštaju i više nego duplo jeftinije od ovih sa micro-motor-warehouse.com i konačno danas stigli ali pre frejma za whoop-a kao i f3 kontrolera ali nema veze bar imam sa čim da letim. Ono što se meni dešava a to navode neki prodavci ovih motora jeste lagano podrhtavanje na malom gasu kao i na hoverovanju ali samo na stability modu. POdrhtavanje se ne oseća kada se vozi malo brže tako da nekada ni ne smeta. Pošto letim u akro modu to se i zaboravilo. Motori su istih performansi kao i oni 17.000 sa micro-motor-warehouse.com čak imam neki osećaj da te motore pravi ista firma.
Za sada moja svaka preporuka i za whoop-a a i za blade nano qx FPV ko ga ima ili ga je sam kao ja pravio...
Jedva čekam da mi stigne FC pa da mogu malo da se snize vrednosti nekih pidova pa će valjda da leti kao podmazano.
toliko od mene o ovim motorimaa  evo i link ka njima
https://www.aliexpress.com/item/Micro-Motor-Warehouse-Blade-Inductrix-Tiny-Whoop-Fast-Motor-Set-CL-0615-for-FPV-90mm-130mm/32761419275.html?spm=2114.01010208.3.1.cWUdJc&ws_ab_test=searchweb0_0,searchweb201602_6_10065_10068_10000009_10084_10083_10080_10082_10081_10060_10061_10062_10056_10055_10037_10054_10033_10059_10032_10099_10078_10079_10077_427_426_10103_10073_10102_10096_10052_10050_10106_10051-10102,searchweb201603_9,afswitch_5&btsid=51fc8aea-e926-4a44-95f2-809e1cd7502a
Post by: gerotmf on December 28, 2016, 10:09:46 PM
Hvala za info, baš sam te i ja naručio ali još nisu stigli .. super :)
ja sam još ovaj FC naručio uz njih,
https://www.aliexpress.com/item/SP-RACING-F3-EVO-Brush-Flight-Control-Board-For-90mm-120mm-80-mm-FPV-Mini-Micro/32757255352.html?spm=2114.13010608.0.0.jSFn2j (https://www.aliexpress.com/item/SP-RACING-F3-EVO-Brush-Flight-Control-Board-For-90mm-120mm-80-mm-FPV-Mini-Micro/32757255352.html?spm=2114.13010608.0.0.jSFn2j)
i taj je več stigao, samo sam povezao na komp da vidim ako radi, i nisam još ništa nameštao - čekam motore pa da menjam sve odjednom.
Post by: lazar89nis on January 02, 2017, 01:22:51 PM
Leteo sam danas po dvoristu posto je fenomenalan dan. Imam samo jedan problem, baterije duplo krace traju po ovom hladnom vremenu :( jel ima neka fora da ih umotam u nesto da duze traju? :D
Post by: marko.jovanovic on January 02, 2017, 01:49:31 PM
Ima fora.
Sačekaš maj i leteće normalno... :big smile
Probaj sa stiroporom on je odličan izolator a i ona izolaciona tanka folija koja se stavlja pod laminat može da pomogne.
Post by: fantombp on January 02, 2017, 10:31:46 PM
I meni je stigao qx 95 ali imam problem sa otpadanjem elisa. Ima i neko takav problem i kako je resen. Probao sam super lepak ali nije resenje.
Post by: lazar89nis on January 02, 2017, 10:34:21 PM
Uzmi nove propelere. Ja sam odmah zamenio za ladybird props
Post by: marko.jovanovic on January 21, 2017, 06:44:57 PM
Konačno i mene da  sunce ugreje posle 2 meseca čekanja na frejm koji je zalutao.
 (yay) (yay) (yay)
(https://s30.postimg.org/5qrlobuod/20170121_181927.jpg) (https://postimg.org/image/5qrlobuod/)
Ja imam beecore dsm2 varijantu i malo je falilo da sve izgazim jer u toj varijanti FC pravi probleme.
ceo dan sam izgubio tražeći rešenja i na kraju uz pomoć gerotmf, kome se ovim putem zahvaljujem na linku, i uz pomoć nekih foruma uspeo sam da dovedem da leti onako kako ja hoću na betaflight-u.
Za sve one koji uzimaju DSM2 varijantu da podelim i ja da nemaju problem
Da bi leteo kako treba i da ne bi išao gde se njemu ćefne i da ne bi stalno njakali bez potrebe trimove rešenje je u podešavanjima sa ovog linka
https://www.phaserfpv.com.au/blogs/blog/eachine-beecore-tiny-whoop-build-betaflight-3-01-with-settings-dump
Na kraju  treba  prekopirati sve komande sa ovog linka u CLI, posle toga otkucati exit, podesiti modove i naravno način povezivanja ppm s-bus....
Nakon toga  na spektrumu morao sam da podesim otklone komandi maksimalno ali samo onoliko koliki je maksimalan otklon u betaflightu +-1-2% i naravno centralne pozicije.
Tek nakon ove operacije quad je počeo da leti kao pčela.
Post by: mikijus on January 25, 2017, 10:50:22 AM
malo sam budzio qx90 :)
https://www.facebook.com/photo.php?fbid=10155192098387345&set=a.74871192344.89181.785277344&type=3&theater&notif_t=like&notif_id=1485336078829743
novi ram :
novi motori :
http://www.banggood.com/4X-Chaoli-CL-820-8_5x20mm-Coreless-Motor-for-90mm-150mm-DIY-Micro-FPV-RC-Quadcopter-Frame-p-1069067.html?rmmds=myorder
kamera :
i zalemo sam JST 1.25mm konektore
imate li sugestije za pidove ...posto su pidovi sa qx90 ....mislim zbog rama :)
Post by: mikijus on January 27, 2017, 06:10:43 PM
Izgleda  da moze :)
stavio sam mu fabricke pidove od ex100 i sada vec moze da se leti nije stabilan kao qx90 ,ali i ovako po sobi je super zanimljivo :)
www.youtube.com/watch?v=PMCobPkA16c
Post by: gerotmf on February 01, 2017, 10:27:08 PM
Super :) Probaj da namestiš prepreke više da ti ne smeta ground efekat, ja se totalno izgubim kad moram ispod stolice da letim pošto prosto zapleše toliko nisko.
Post by: mihajlo on February 04, 2017, 08:37:28 AM
otoplilo pa se malo vezbalo
https://www.youtube.com/watch?v=g0VctEpVPJ0
Post by: marko.jovanovic on February 04, 2017, 08:48:30 AM
Lepo.  :)aplauz
Primetio sam da se malo bojiš da prođeš kroz otvore
Možda ti je ovo među prvim letovima pa je to i za očekivati.
Moj savet ti je da kada prolaziš kroz otvore nikada se ne fokusiraš u gledanje u sam otvor nego što dalje kroz njega.
Vremenom kada stvoriš sliku prostora oko quada prolaženje će biti kao kroz puter, pa iako se zakači nekada nešto na to se neće puno obraćati pažnja. A andrenalin ima samo da pumpa!
Na žalost u nedostatku pravog simulatora za multirotore primorani smo da učimo na svojim greškama i da to u početku malo skuplje platimo u delovima koji se salome, ali posle to dođe na svoje....
Post by: mikijus on March 02, 2017, 11:36:48 PM
sve nas je vise :)
www.youtube.com/watch?v=YlqDAjXYjyw
Post by: brankelot on March 03, 2017, 12:30:36 AM
bravom mikiliks . Uzeo sam i ja jedan . samo cekam stitnike za elise :)
Post by: brankelot on March 20, 2017, 02:08:34 PM
cime ste lepili elise ? dok mi nestignu nove
Post by: mikijus on March 23, 2017, 05:21:13 PM
kad se vidimo dacu ti Ladybird dok ti tvoje ne stignu :)
Post by: mikijus on March 24, 2017, 07:34:42 PM
Doslo prolece :)
www.youtube.com/watch?v=t3b97tyvkw4
Post by: brankelot on March 24, 2017, 08:01:11 PM
hahahaha. dobro ti ide .
Post by: marko.jovanovic on March 24, 2017, 08:44:14 PM
Fino samo ti mali quadovi na velikim povrinama zbog relativno male brzine izgledaju kao da se vuku jedva.
Da bi dočarao brzinu moraš da letiš nisko i da su ti manje prepreke kroz koje prolaziš ili koje obilaziš.
Probaj sam sebi po tom dvorištu da postaviš na zemlji neke prepreke ali ne visoke pa vežbaj brze prolaske ispod...
Post by: mikijus on March 24, 2017, 09:01:55 PM
Hocu..samo da pokosim travu :)
Post by: mikijus on April 04, 2017, 09:28:24 PM
stigao mi je novi ram
http://www.ebay.com/itm/90mm-6-1g-DIY-Micro-Carbon-Fiber-FPV-RC-Frame-Kit-for-8-5x20mm-Coreless-Motor-/371674356311
https://www.facebook.com/photo.php?fbid=10155405913332345&set=gm.1661747937175490&type=3&theater
samo donja ploca 3,6 grama
Post by: gerotmf on April 07, 2017, 12:31:38 AM
imam i ja taj, lepo leti sa walkera lady bird propovima, taman veličina. 1s baterija od 300-500mAh .. sve paše pošto imaju motori i previše snage za tu težinu.
To je ovaj dole desno, dole levo je 120 mm, isti frame sa gemfan 65mm propovima, skinuo sam fpv opremu dole (trebala mi za drugi model), ali sve je to lepo letelo sa 600tvl kamericom i vtx-03. Ovako bez ičega leti i više od 8 minuta na 500mAh bateriji, ali je prebrzo za po stanu :)
Post by: mikijus on May 17, 2017, 10:17:02 PM
Posto mi je prosli quad pobegao ....   mmmm
evo ga novi bild
ram
https://www.banggood.com/90mm-Carbon-Fiber-DIY-Micro-Mini-FPV-Quadcopter-Frame-Kit-2mm-Support-8_5x20mm-Coreless-Motor-p-1055212.html?rmmds=myorder
flight controler
https://www.banggood.com/Eachine-FRF3_EVO-Brushed-Flight-Control-Board-Built-in-FRSKY-Compatible-SBUS-8CH-Receiver-p-1091779.html?rmmds=search
kamra
https://www.banggood.com/Eachine-EF-02-AIO-5_8G-40CH-25MW-800TVL-VTX-13-Cmos-FPV-Camera-p-1119217.html
motori
https://www.banggood.com/Chaoli-CL-820-8_5x20mm-Coreless-Motor-for-90mm-150mm-DIY-Micro-FPV-RC-Quadcopter-Frame-p-1054803.html?rmmds=myorder
propeleri
https://www.banggood.com/Wholesale-3-Set-Walkera-QR-Ladybird-Spare-Parts-Main-Blades-Propellers-QR-Ladybird-Z-01-p-47127.html
Post by: marko.jovanovic on May 17, 2017, 10:28:25 PM
Kako misliš pobegao?
Definiši malo.... mmmm
Post by: mikijus on May 18, 2017, 06:35:25 PM
lepo izgubio sam ga ------visoka trava i nekoliko jelki i tuja preko 10 metara
trazili ga je nas cetvorica ceo dan i odustali...
nestala mi slika sa kamere a ja probao napamet da ga vratim....ocigledno to ne treba raditi :)
Post by: marko.jovanovic on May 18, 2017, 08:19:05 PM
Pravilo broj jedan.
Nikada ne leteti po gustoj travi osim ako nemate neki uređaj koji će biti siguran za traženje kao na primer ovo:
https://hobbyking.com/en_us/loc8tor-lite-set.html
Ali je to preveliko za tako male modele.
Vrlo često se ostane bez napajanja pa dzaba i biperi i sve ostalo...
Na žalost najbolje je ako je moguće zapamtiti poslednju lokaciju.....
Ja sam imao dva slučaja jedan su bili kukuruzi jedan soja.
Na svu sreću uspeo sam da nađem quad i od tada nikada više iznad takvih površina...
Takođe jedan savet kada se padne pre odlaska proveriti tu gde je model jer su svi delovi na broju jer kada se ode teško ćeš se ponovo vratiti na isto mesto. Meni se desilo da tako izgubim TX i antenu. A nimalo nije sitna stvar. Možeš misliti kako se onda lako izgube delovi sa manjih quad-ova....
Post by: zloxi on May 18, 2017, 10:34:11 PM
 ;D ;D ;D Ma stavi mu ovo...
(https://www.dpl-surveillance-equipment.com/gallery/Big-Brother-Ankle-(GPS)-Tracker.jpg)
Post by: mikijus on May 23, 2017, 07:06:38 PM
https://www.facebook.com/photo.php?fbid=10155571874562345&set=a.74871192344.89181.785277344&type=3&theater
Post by: mikijus on May 25, 2017, 11:09:14 PM
a i evo prvog dana letenja u betaflight 3.1.7 u airmodemodu   (yay) (yay) (yay)
https://youtu.be/Ht4r7H_K93M
Post by: mikijus on May 26, 2017, 11:24:49 PM
jel ima neko da je sprzio elektroniku na  Eachine EF-01 treba mi socivo...  (<--)
Post by: drej37 on May 31, 2017, 12:57:33 PM
imam socivo...
javi se da proverimo dimenzije na 0649088086
ili nas kontaktiraj preko:
https://web.facebook.com/xdroners/
happy flying
Post by: mikijus on June 01, 2017, 07:21:45 PM
ljudi ovo nikad jeftinije
frsky verzija 25.44 e
https://www.banggood.com/Tiny-QX90-90mm-Micro-FPV-Racing-Quadcopter-BNF-Based-On-F3-Flight-Controller-FrSKY-Taranis-X9D-p-1069614.html?rmmds=search
Post by: zloxi on June 07, 2017, 10:22:44 PM
Ne isplati se vise kupovati delove vec pakovanje od ovakvih 5 komada odmah :D
Post by: marko.jovanovic on June 08, 2017, 07:37:21 AM
Ispadne cena kao samo kamere...
VRlo povoljno, čak se i ja razmišljam da ga uzmem iako nemama baš sjajno mišljenje o njemu, makar ću jeftino da uzmeme FC, i kameru.
Post by: mikijus on June 08, 2017, 04:25:18 PM
i risiver za frsky je super...ali vise nije tako jeftin
Post by: marko.jovanovic on June 08, 2017, 05:15:18 PM
Bio je što ne znači da ponovo neće biti.
Mnogo je kineskih prodavaca koji su novi na tom sajtu pa na trenutke se pojave takvi popusti ne bi li skrenuli pažnju na sebe pa makar i izgubili....
Post by: mikijus on June 08, 2017, 07:59:06 PM
lepo mesto na kosutnjaku
https://www.youtube.com/watch?v=TdP6IWwwQ04&index=1&list=PLE7zuCkLs7XoTPvtKkP3tRHVlSsCLTOL5&t=3s
Post by: brankelot on June 08, 2017, 09:22:52 PM
izvezbao si se mikijus. Jesi to po telki vezbao :)
Post by: mikijus on June 08, 2017, 09:34:26 PM
ajde bre Badzi nema te da letimo..... ovaj kosutnjak je super  :)
pri tom ovo leti Ski..danas su leteli pa mi poslali da vidim mesto  :)
Post by: brankelot on June 08, 2017, 10:00:55 PM
nemam naocare . ja letuckam ovako "na oko " . a i ulupao sam ga danas nesto , otkazuje mi poslusnost prijemnik
Post by: mikijus on June 09, 2017, 09:20:58 AM
o tome ti i pricam imamo mi....... a kad probas.... i kad se napalis na fpv ima da menjas velikog  za cvike i neku zujelicu :)
Post by: zloxi on June 09, 2017, 09:45:14 AM
Evo i 2s zabe skoro za dzabe  :_D
https://www.banggood.com/Eachine-Flyingfrog-Q90-Micro-FPV-Racing-Quadcopter-BNF-with-F3-5_8G-200mW-VTX-1000TVL-Camera-p-1124456.html?rmmds=search (https://www.banggood.com/Eachine-Flyingfrog-Q90-Micro-FPV-Racing-Quadcopter-BNF-with-F3-5_8G-200mW-VTX-1000TVL-Camera-p-1124456.html?rmmds=search)
Post by: firebird on June 12, 2017, 07:24:04 AM
Poručeno žapče i video prijemnik, onaj što se kači na telefon. Biće dovoljno da se zezam po dvorištu i sokačetu....Preneću utiske kad stigne  :)
Post by: marko.jovanovic on June 12, 2017, 01:58:55 PM
svi ti prijemnici koji idu na telefon neće te baš usrećiti.
Za početak može da ti posluži dok se ne naučiš komande ali svi oni imaju ogroman lag ili ti kašnjenje slike tako da letenje sa njima kroz neke prepreke je jako stresan posao. Posebno će biti problem kada daš komandu pa na ekranu vidiš kako tek posle nekog vremena quad reaguje na nju.
Veruj mi i 20 mili sekundi kašnjenja je ovde ogromno a ne 100 i više
Post by: mikijus on June 12, 2017, 10:27:31 PM
https://www.youtube.com/watch?v=bxbGTzuHo48&t=32s&list=PLE7zuCkLs7XoTPvtKkP3tRHVlSsCLTOL5&index=1
Post by: firebird on June 13, 2017, 07:28:56 AM
Zabavni video snimci  :) , ja sad ne mogu da dočekam da stignu moje igračke...
Post by: srkipa on June 13, 2017, 10:18:41 PM
Lepo se to leti Mikijus a kad letimo zajedno?
Sve nas vise ima u ovoj micro varijanti mozemo i jedan mali skup da organizujemo.
Post by: mikijus on June 13, 2017, 10:39:33 PM
ajde mozemo sutra...planirali smo nas trojica na kosutnjak....
Post by: srkipa on June 13, 2017, 11:07:53 PM
Cujemo se telefonom pa se dogovaramo.
A evo i mojih malisana
Eachine Racer 130 i Smart100 diy varijanta, slike su malo losije takva mi kamera na fonu.
(http://i65.tinypic.com/2lbn7k0.jpg)
(http://i63.tinypic.com/2nla3jq.jpg)
(http://i64.tinypic.com/20zv3mx.jpg)
Post by: mikijus on June 13, 2017, 11:13:14 PM
okrenu cu sutra i Andreja pa se mozda i skupimo :)
evo gde letimo donecemo i kapije
https://www.youtube.com/watch?v=pplha8fDKP8&list=PLE7zuCkLs7XoTPvtKkP3tRHVlSsCLTOL5&t=6s&index=1
Post by: srkipa on June 13, 2017, 11:22:26 PM
Dobro si se ti izvezbao sa micro quadom i acro modom, svaka cast.
Taman sutra da probas i ovog mog racera sa brusless motorima.
Koliko vidim sve je veca zainteresovanost za micro quadcoptere (do 150mm) u svetu pa i kod nas po meni mnogo vise prednosti u odnosu na veliku bracu (od 200mm) ako nista drugo potrebna je manja staza i mnogo su bezbedniji po okolinu.
Title: Re: QX90 - dali ga neko ima
Post by: marko.jovanovic on June 14, 2017, 04:59:53 AM
Ti vaš i jesu donekle bezbedni.
Pogledajte ovo
https://www.youtube.com/watch?v=wCbrEikz4vE&t=777s
Svaka čast na okupljanju polako nas je sve više.
Ja imam idealno igrališe od 12 hektara a li na žalost u ovom usranom gradu nema niko ko bi mi se pridružio, letim sam
Post by: srkipa on June 14, 2017, 10:32:01 AM
A odakle si mozda ima neko ko je u blizini?
Ajde ovako malo da se upoznamo pa ko zna mozda i neznamo koliko smo blizu jedni drugima
Ja sam i z Panceva letim uglavnom micro quadcoptere i pocetnik sam u tome.
Post by: srkipa on June 14, 2017, 10:46:50 AM
Sto se tice micro quadcoptera pogotovo manjih od 100mm u brushless varijanti zbog velike brzine a male tezine i velikih acro mogucnosti a sve to zbog velike potraznje u svetu ( citaj zakona o quadcopterima u mnogim zemljama) toliko je inovacija i tehnickih noviteta izbaceno u poslednjih par meseci da se to vise nemoze pratiti, sve je jasno kad se pogleda koliko je novih micro modela izaslo u zadnjih mesec dana a sve to vodi ka 3s i 4s setapovima i velikim brzinama.
Pomenuti lizard 99 je toliko brz da je to jako tesko leteti na livadi a opet tako mali i precizan za uzivanje u malim parkicima ja licno neznam dal cu uopste i kupovati nesto vece od 150mm gledajuci da mi za sve vece od 130mm treba i veci prostor za letenje dok malog smarta od 100mm letim po dvoristu sa ulazima u kucu i izlazima kroz prozor. Da napomenem da skoro svaki micro brushless quad moze bez problema poneti mobius mini (ili slicne HD camere) i lepo leteti sa njom.
Post by: marko.jovanovic on June 14, 2017, 02:03:32 PM
Ja sam iz Sremske Mitrovice, verovatno sam jedini koji ovde leti. nije mi problem da nekqada dođem do vas ali trenutno ne raspolažem zavidnim modelom za te vaše prostore. Letim trenutno 210mm x realacc 2204 emax rs-s motore, 4s 1300 a od manjih stvari imam whoop-a i blade nanoxq koji bi mogao da leti tu kod vas sasvim korektno ali ako nema jaceg vetra.
Sledeća stanica če biti najverovatnije lizard ili ako izađe neka druga varijanta nečega.
Mada čekam da izađe nešto sa mini runcam swift kamerom jer ove cmos mi idu na živce zbog jako lošeg odziva na jake promene svetla što zna da iritira. Što se tiče brzine može on i sporo da leti pitanje je samo rukovaoca, ali kada sporo letiš onda to nije to niti je efekat adrenalina postignut. Lepo se vi zezate sa tim qx-ovima i sve je to ok ali ipak mislim da bi kasnije trebali da pređete na brže verzije jer dosadi.
Post by: zloxi on June 14, 2017, 03:27:56 PM
https://www.banggood.com/de/Runcam-Split-1080P-DVR-FPV-Camera-WithWithout-WiFi-2_5mm-FOV-130-165-Degree-NTSC-PAL-Support-64G-TF-p-1159850.html?rmmds=search (https://www.banggood.com/de/Runcam-Split-1080P-DVR-FPV-Camera-WithWithout-WiFi-2_5mm-FOV-130-165-Degree-NTSC-PAL-Support-64G-TF-p-1159850.html?rmmds=search)
Post by: srkipa on June 14, 2017, 03:37:20 PM
Sve zavisi ko sebe gde vidi u ovom hobiju, naravno da treba da se unapredjujemo sa brzim quadovima ali ja licno na vece od 150mm necu uskoro preci mislim da brushless micro quadovi imaju vecu iskoriscenost (livada, suma, mali park) na primer mali racer 130 sa brushless motorima bi mogao komotno da letim tu kod tebe u S.M. na rusevinama na zitnom trg, glavni park iza crkve mozda cak i na gradskoj plazi, sad svako ima nesto svoje ali mnogo napredniji stranci sa preko 10 quadova u svom posedstvu se i posle svega lepo nalete micro quadicima pogotovo kad imaju i drustvo pored sebe a veruj mi adrenalin skace i kad se lete ove male zujalice pogotovo na malom i tesnom prostoru i opet kao i sto sam rekao svako ima nesto svoje koje ja postujem. Nadam se da cemo se videti negde pa leteti i druziti se jer to je nesto sto doprinosi uzitak u svemu ovome.
Post by: marko.jovanovic on June 14, 2017, 04:18:06 PM
@zloxi
Ne verujem ničemu što nema 600 tvl sony ccd senzor ili eventualno cmos 600tvl
sve preko toga imaš kašnjenje i to ti ne ide u prilog.
Postoji mini kamera swit sa gore pomenutim senzorom i to je ok ali nije još toliko mala da može da stane koliko vidim na onog lizarda.
POgotovo kada na kameri koja kao ova ima da se uključi snimanje 1080p odmah kašnjenje skače u nebesa.
a to što piše low latency to piše i na tarabi. Što nisu naveli koliko je to?
Bilo kako bilo ne kažem da nije dobro zezanje i to si potpuno u pravu  ili ja nisam video u specifikacijama. ali ipak ovi veći daju veći adrenalin.
Vozio i jedne i druge.
JA se nauživam i kada vozim whoop-a kod kuće tako da nije mi problem da letim ni te male.
U Sremskoj Mitrovici ima spomen park površine 12 HEKTARA i iz mojih videa možete videti kakvo je to mesto za letenje i malih i velikih quadova. Ko nije video evo par videa pa neka se uveri.
Pored ovog imamo još jedan park blizu KPD-a (zatovra) koji je takođe dobar za letenje posebno ovih malih.
https://www.youtube.com/watch?v=hsUjrikNWWg
https://www.youtube.com/watch?v=onucXdU7M5Y
Post by: marko.jovanovic on June 14, 2017, 04:20:30 PM
I jedina mana tih malih zujalica jeste što kda letiš daleko od sebe pa ga skrljaš u neku duboku travu a ostane bez napajanja nahebo si dog ga ne nađeš ako nisis nismio let makar na dwr-u
Post by: zloxi on June 14, 2017, 08:50:14 PM
Ima ovde dobar neutralan test kamere... Mislim da je ok za frejmove koji su >150...
Za ostale zujalice kao sto je lizz. je prevelika
https://www.youtube.com/watch?v=2CgoaR82F0A (https://www.youtube.com/watch?v=2CgoaR82F0A)
Post by: marko.jovanovic on June 15, 2017, 11:06:25 AM
Evo vam jedan test kašnjenja pri čemu se vidi da je kašnjenje ove kamere jako loše.
https://oscarliang.com/fpv-camera-latency/Ne kažem da je amera loša ali za jurnjavu pogotovo pri većim brzinama ovo nema smisla stavljati na quad.
Ako letita brzinom od 100 na sat što na ovim quadovima većim pa čak i lizardu koliko vidim nije problem za jedan sekund se preleti oko 28 metara.
Kada je kašnjenje 50 mili sekundi koliko je za ovu kameru izmereno ili ti 0.05 s znači da imate kašnjenje od 1.4m
Tj kada date komandu spram onoga što vidite na ekranu quad je već prešao odavno 1.4m
E sada kada se sporo leti to može i da se toleriše al kada se leti brzo i kroz uske prolaze teško da će da bude zanimljivo...
Ja sam ipak zadovoljan sa hs1177 kamerama pa makar morao da sinmam u preko dvr-a
HD snimak mi nije zanimljiv trenutno tako da ću sačekati dok se ovo ne popravi u ekim kasnije verzijama.
Inače za lizarda bi možda mogla da posluži runcam micro kamera
https://oscarliang.com/micro-swift-runcam/
Post by: mikijus on June 15, 2017, 12:57:50 PM
...sutra posle podne letima na topcideru sa micro quad-ovima   ()-() ()-() ()-()
ako ima neko u blizini da hoce i moze nek mi se javi da mu objasnim gde je staza .....na  063368799
Post by: srkipa on June 15, 2017, 11:27:59 PM
Extra motorcici za neki micro quadcopter a totalno jeftini
https://www.banggood.com/Racerstar-Racing-Edition-1103-BR1103-8000KV-1-2S-Brushless-Motor-Pink-For-50-80-100-RC-Multirotor-p-1113140.html?rmmds=search
cod za dodatnih 8%  36bgc8
A evo i 4 in 1 esc 6A za njih ko stvoren
https://www.aliexpress.com/item/Super-s-BS06D-4-In-1-6A-BLHeli-S-ESC-Support-DSHOT-2S-LiPo-for-RC/32814725189.html?spm=2114.01010208.3.2.7Fepys&ws_ab_test=searchweb0_0,searchweb201602_1_10152_10065_10151_10068_10136_10137_10060_10155_10062_437_10154_10056_10055_10054_10059_303_100031_10099_10103_10102_10096_10052_10053_10142_10107_10050_10051_5030017_10084_10083_10119_10080_10082_10081_10110_519_10111_10112_10113_10114_10179_10182_10078_10079_10073_10123_10120_10189_142-10120,searchweb201603_13,ppcSwitch_5&btsid=58cba6c5-16f4-4b58-9804-efabbadf0c09&algo_expid=b8b0fb8f-8748-40e4-9ea4-8e54dd3bc016-0&algo_pvid=b8b0fb8f-8748-40e4-9ea4-8e54dd3bc016
Post by: zloxi on June 16, 2017, 07:28:39 AM
404 Page Not Found
We couldn't find what you're looking for.
Post by: srkipa on June 16, 2017, 08:59:55 AM
Neznam zasto izbacuje tako
https://www.banggood.com/Racerstar-Racing-Edition-1103-BR1103-8000KV-1-2S-Brushless-Motor-Dark-Blue-For-50-80-100-Multirotor-p-1113139.html?rmmds=search
Evo ga sad. Na 2s bateriji i kingkong 65mm 89g trust 4.66a to i neki frame 100mm extra kombinacija.
Post by: mikijus on June 16, 2017, 11:08:52 AM
danas u 16 na topcideru ..a evo i lokacije
https://www.google.rs/maps/place/44%C2%B046'54.7%22N+20%C2%B026'21.1%22E/@44.7819942,20.4376568,17.92z/data=!4m5!3m4!1s0x0:0x0!8m2!3d44.781858!4d20.439182?hl=en
Post by: brankelot on June 16, 2017, 11:19:52 AM
Zavidim vam .Lep provod  (pijanoo)
Post by: mikijus on June 16, 2017, 08:52:43 PM
Danas se koliko ja znam letelo na dva mesta u Beogradu....
Na uscu kod muzeja ......Andrej i ekipa sa velikim (250) i
ekipa sa micro quad-ovima na topcideru...dva super druzenja    :)aplauz :)aplauz :)aplauz
probao sam srkipa  Eachine Racer 130 i odusevio se  :) :) :)
sve moze ko qx90 :)
https://youtu.be/wG1tPI16gSw
a evo i skijev video
https://www.youtube.com/watch?v=qNJYJ6AFG_M
Post by: marko.jovanovic on June 16, 2017, 10:16:54 PM
https://www.youtube.com/watch?v=d2nRrVENEYM
Airmode može da bude aktiviran i u akro, angle ili bilo kom drugom modu.
airmode nije način stabilizacije i korišćenja žiroskopa nego samo iskorišćavanje komandi pri malim obratajima gasa.
Post by: srkipa on June 16, 2017, 11:46:46 PM
Letelo se danas lepo na Topcideru neki su prolazili kroz gejtove a neki smo ih i rusili  (fiu)
evo malo slika micro druzine a i jedan kombinovan snimak.
(http://i68.tinypic.com/2qddevk.jpg)
(http://i66.tinypic.com/2yv08sk.jpg)
(http://i63.tinypic.com/2cwn4mq.jpg)
https://youtu.be/wydKWLjzP5Y
Post by: srkipa on June 17, 2017, 12:00:17 AM
Evo i snimak  recer-a 130 u freestyle ali na samom kraju baterije
https://youtu.be/HtapF4BqWkE
Post by: mikijus on June 17, 2017, 12:05:28 AM
https://www.youtube.com/watch?v=XY7JO3_kHgU
samo ja ne znam flipove :)
Post by: srkipa on June 17, 2017, 12:49:48 AM
I da dodam da recer-a niko nije leteo preko 75-80% gasa
Post by: Asterix on June 17, 2017, 01:29:08 AM
Menjaj tu fpv antenu ili probaj da stavis neki micro lc filter otice ti oci  :big smile
Post by: srkipa on June 17, 2017, 01:35:22 AM
Antena jeste losa ali u toku leta nema toliko smetnji a i mi smo na drugoj strani tih drveca pa tako da su smetnje najvise staticke od samih krosnji ali u svakom slucaju treba da se zameni antena
Post by: Asterix on June 17, 2017, 01:40:25 AM
Tebi treperi i kada miruju tj kada je pao, zbog toga ti kazem nesto ne stima tu :big smile
Post by: marko.jovanovic on June 17, 2017, 07:37:55 AM
Kada je pao bio je okrenut naopačke i zabijena natena u travu zato je snimak zezao, lc filter ti treba kad se pojave horizontalne linije pri dodavanju gasa tj kada esc-ovi prave smetnje. Ugavnom sva napajanja na današnjim pločama imaju lc filtere tako da više nije potrebno zezati se sa tim. i onako se sastoji od 2-3 komponente što je rešivo i što su svi uradili (proizvođači).
Inače na DVR-u koliko sam shvatio i koliko su mi ljudi pričali daleko više smetnji snimi nego što ih ti vidiš ili uočiš dok letiš.
Džaba tu i dobra antena kada su ti mikro TX-ovi blagi užas. a  i rade na 25 mW što bi trebalo da pojača probojnost u zatvorrenom prostoru i  gustišu ali na tarabi piše jedno a u stvarnosti je drugo na žalost. u ostalom sve je to ok jer treba da budemo zadovoljni šta su do sada uspel da spakuju u tako mali prostor tih quadova i da pri tome koliko toliko radi posao.
DO pre 3-5 godina niko nije ni sanjao da će biti ovako neka zezancija...
Post by: mikijus on June 21, 2017, 10:32:55 PM
da se veatimo malo letenju ...
danas smo prvi put poceili da merimo vreme...i to je dovelo do nekoliko sjajnih voznji  :)
evo mog rekorda 25 sec...
Ski je provozao za 24 sec  ...napeto :)
https://www.youtube.com/watch?v=vVOpIesbmzs
a evo ka i ski-jev snimak
https://www.youtube.com/watch?v=qIF3MF9vISY
Post by: srkipa on June 22, 2017, 08:43:00 AM
Kako vi uzivate!
Post by: mikijus on June 22, 2017, 10:02:10 AM
aj sutra ako bude ok vreme...pa da letimo kod mene
Post by: srkipa on June 22, 2017, 11:23:53 AM
Tu kod tebe moj smart ima prednost zbog veceg ubrzanja
Post by: mikijus on June 24, 2017, 12:49:07 PM
2017-06-23 14:13 61200 CARINA GPC BEOGRAD - 11200 GPC BEOGRAD Otprema
2017-06-23 10:19 11003 IZMENIČNA POŠTA Za carinu
2017-06-23 10:08 11003 IZMENIČNA POŠTA Prispeće
stigao QX90 za rezervne delove ...cena samo 25e   :)aplauz
Post by: mikijus on June 26, 2017, 04:02:20 PM
ovaj QX 90 je malo drugaciji od prvog kog sam narucio proslog septembra....
izgleda da je fc iz qx90c  ima na sebi risiver za FRsky i dzekove za motore 1.0
Post by: zloxi on June 26, 2017, 09:15:31 PM
To je omen, konacno vreme da uzmes FRsky risiver :D  :)aplauz
Post by: mikijus on June 26, 2017, 09:53:26 PM
imam FRsky modul za Turnigy  9xr  ovo mi i odgovara   oo))
Post by: srkipa on June 28, 2017, 08:47:22 AM
Letelo se malo i u Pancevu na keju.
https://youtu.be/Wj_JBMlWpVg
Post by: firebird on June 30, 2017, 07:36:05 PM
Stigla žabica i prijemnik...... a ja van zemlje ")
Nema veze, za par dana se vraćam, pa kad podignem paketiće postavljam slike i utiske.....a onda mogu da počnem da se zabavljam kao vi  :big smile
Post by: srkipa on July 01, 2017, 11:56:43 PM
Vezbamo i treniramo prste a pritom uzivamo!
https://youtu.be/wEgftK3rO6M
A imamo i neobicne gejtove!
Post by: firebird on July 04, 2017, 11:19:54 PM
Eachine FlyingFrog q90  i video prijemnik OTG UVC što se kaci na telefon
      (http://i895.photobucket.com/albums/ac160/bokiKG/20170702_200444_RichtoneHDR_zpsghlqdnxb.jpg)
      (http://i895.photobucket.com/albums/ac160/bokiKG/20170702_zpsca9nunrh.jpg)
celo popodne sam se zezao da uglavim pištalicu unutra
       (http://i895.photobucket.com/albums/ac160/bokiKG/20170702_213549_zpszcdbd7ux.jpg)
Ima kašnjenja u slici ali ništa značajno , mož' se tera  ;namig
Na žalost baterija koja je stigla je falična pa nemam ni 2 min letenja, jedna ćelija padne ispod 1v  ")
Toliko za sad, postavljam video čim malo uvežbam baratanje...i čekam u međuvremenu nove baterije.
Post by: brankelot on July 04, 2017, 11:49:01 PM
jhesu li te rebnuli za carinu ?
Post by: uros2002 on July 04, 2017, 11:58:44 PM
Kakva je slika prko ovog OTG UVC za telefon?
Koliki je domet?
Hvala
Post by: firebird on July 05, 2017, 07:52:34 AM
Ništa me nisu rebnuli, stiglo kao obično pismo  :)
Što se tiče slike sasvim ok. Telefon montiran u VR naočare.
Nadam se da ću popodne imati više vremena da napravim koji snimak pa da vidiš.
Softver GO FPV ima opciju da snima direktno na tel i da prebaciš sliku sa stereo na mono pogled pa da gledaš normalno (bez naočara)
Post by: srkipa on July 05, 2017, 09:15:06 AM
Obavezno zameni proprllere sa nekim boljim 55mm (ladybird) inace ti stock propelleri su tesko sr...e puno vibracija a trust katastrofa.
Post by: firebird on July 06, 2017, 08:40:38 PM
 Zamenicu obavezno sa ladybird al' nisam jos narucio. Primetio sam neke cudne trzaje u radu motora, kao da na delić sekunde dodaš gas pa vratiš na normalu i to se ponavlja nasumicno 5-6 puta u toku leta od 3-4min. Pokušaću da snimim pa da vidite o čemu pričam, možda je neko imao sličan problem i rešio ga.
Evo i snimka leta, napravljenog danas čim smo izašli s' posla  :big smile. To je ujedno i moj prvi FPV let, pa ne zamerite što nije profi...još se privikavam na celu priču  (yay)
                   https://youtu.be/86PI7-IdgKo
Post by: marko.jovanovic on July 06, 2017, 10:33:46 PM
Odlično za početak, savršeno to tebi ide.
Pokušaj da se fokusiraš na to da kada radiš ruder komandu odnosno okretanje quada uvek dodaš malo gasa da ti ne gubi visinu jer tada u tom slučaju obično radi jedan motor više kako bi ga okrenuo pa ti mali quadovi kao i whoop znaju da u okretima gube visinu, naročito u hover modu. Možeš to i umiksovati na stanici ako umeš...
U svakom slulčaju odlično.
Post by: firebird on July 07, 2017, 10:18:48 PM
Evo snimio sam kako se čudno ponaša žapče, tj. skakuće.
   https://youtu.be/LPyvXpG8Zqk
Ovo se dešava kad armiram qvad, kad nije armiran sve stoji u mestu.
Kad se povežem na betaflight da vidim šta se dešava nema ovakve pojave.
Jel neko imao sličnih problema?
Post by: mikijus on July 08, 2017, 07:15:48 PM
prva polovina klipa.... nista mi nije jasno sta se to cuje  mmmm mmmm mmmm
a ovo posle sto skakuce, mozda si u angle modi pa pri poleranju zbog ground effect-a skakuce....
e i da obavezno vezbaj na travi  ;namig  padovi su mnogo bezbolniji  :)
Post by: firebird on July 08, 2017, 08:35:54 PM
U pravu si, nisam lepo objasnio. U prvoj polovini klipa ručica gasa je na nuli u drugoj polovini dao sam gas tek toliko da se pokrenu rotori. U oba slučaja qvad sam radi ovo naglo ubrzavanje motora. U betaflight sam aktivirao opciju da ne pokreće motore kada je gas na nuli. Angle mod.
Post by: marko.jovanovic on July 09, 2017, 05:17:59 PM
Ne znam kod brushed motora ali brzinu okretanja motora u leru možeš da sam podesiš na brushless motorima.
Isto takođe nisam siguran da kod tih motora mogu esc-ovi da se sinhronizuju kod brushless motora se to obavezno radi osim ako esc-ovi ne rade u dshot modu.
Post by: zloxi on July 10, 2017, 10:23:16 PM
E sad mi je jasno sto je toliko jeftin taj zabac :hehe
Post by: firebird on July 11, 2017, 07:58:12 AM
Izgleda da je do prijemnika jer čitam po rcgroups da ljudi imaju problema sa njim, pa menjaju sa orange ili lemon satelitima. Ja nemam ni jedan satelit da probam pa ću za sad da se borim ovako.
E izašlo je na kraju još jeftinije jer su mi kinezi juče refundirali 10$ na kontu falične baterije , tako da je žaba koštala oko 15-16$  :big smile .
Na kraju uvek mogu da je seciram i povadim organe, f3, video grupu, motorčići... lol
Post by: srkipa on July 11, 2017, 04:42:54 PM
Spakovan 2s brushless malisha!
(http://i65.tinypic.com/2i71dfd.jpg)
(http://i63.tinypic.com/1pe5nc.jpg)
Frame Kt100
Motori racerstar br1103 8000kv
Esc 4 in 1 2s 6A
Fc F3evo
Post by: mikijus on July 11, 2017, 08:15:27 PM
vec si ga spakovao  :)aplauz :)aplauz :)aplauz
daj neki video...
Post by: marko.jovanovic on July 11, 2017, 09:13:05 PM
Teraj to na 3s ako može i neke ozbiljnije propelere
Post by: zloxi on July 11, 2017, 11:57:03 PM
Jel radi sad?
Post by: srkipa on July 12, 2017, 12:54:51 AM
Spakovao leteo pa sad i prepakovao!
(http://i64.tinypic.com/zjx768.jpg)
(http://i64.tinypic.com/219x8g1.jpg)
(http://i65.tinypic.com/d4ghw.jpg)
(http://i66.tinypic.com/688msi.jpg)
(http://i65.tinypic.com/nb59fm.jpg)
Motori se greju na 3s previse a i predvidjeni su za 1-2s a i esc je 2s 6A ali i ovako je lud na 3s bi bilo suludo leteti sa ovim propelerima trust po motoru je 69gr sa kingkong65mm 85gr trust po motoru
Sutra cu da bacim koji snimak fpv i Los ako stignem
Post by: drej37 on July 12, 2017, 11:45:34 AM
Bas se lepo zabavljate :)
Ipak si ga prepakovao kao i ja?!
znatno je laksi !
Post by: srkipa on July 12, 2017, 12:58:46 PM
Tako ga svi uglavnom pakuju a sto se tice i 15gr vise na njemu nema nekog velikog znacaja u svakom slucaju pun gas nema smisla ni dati jer je tako jak da pod punim gasom u tri secunde nestaje iz vidokruga
Post by: firebird on July 12, 2017, 10:34:26 PM
Jel radi sad?
Večeras sam na hipodrumu izleteo tri baterije i nisam primetio ovo štucanje. Do duše stalno sam bio u pokretu, vežbao upravljanje na bezbednoj visini, proveravao domet....
Post by: mikijus on July 29, 2017, 12:44:29 AM
opet jeftino za FRsky   :) :) :) :)
https://www.banggood.com/Eachine-Tiny-QX90C-90mm-Micro-FPV-Racing-Quadcopter-Based-On-F3-EVO-Brushed-Flight-Controller-p-1093924.html?rmmds=search
Post by: drej37 on August 04, 2017, 11:49:40 AM
Pozdrav QXovci,
Posto sam hteo da se prikljucim, porucio sam jedan qx90c, ali stigo mi je FrSky protokol a ja ga nemam.
Tako da je je jedan potpuno nov , stigo pre dva dana na prodaju.
Telefon: 0649088086
Andrej
P.s. Da mogu da provalim kako, postavio bi fotku...
Post by: marko.jovanovic on August 04, 2017, 02:41:56 PM
Vrlo verovatno je da možeš da ga modifikuješ da ti radi sa spektrumom recimo.
 Na HK-u imaš recimo spektrumov prijemnik od 1 gram koji može u ppm modu da se nakači na te ploče od qx90.
Košta nekih 7 ako ne i manje eura. Za ostale futabu i flsky nisam siguran da imaju tako male prijemnike.
Sliku postaviš na recimo postimg.org i okačiš ovde link
Post by: mikijus on August 04, 2017, 11:25:59 PM
pitaj admina  :) :) :) :)
Post by: firebird on August 08, 2017, 06:44:20 AM
Da li je neko poručivao skorije motoriće za ovu klasu qvada ali koji rade na 2s, treba mi preporuka. Stradala dva prednja, jedan ne radi u opšte a drugi impulsno. Otvorio sam ih i video da su se potrošile četkice.
[attach=1]
Počinjem da razmišljam o brushless konverziji...
Post by: marko.jovanovic on August 08, 2017, 10:28:40 AM
Ti motori su jako lošeg kvaliteta zato toliko i koštaju. Zbog same konstrukcije imaju neki vek trajanja i tu popravke nema.
Eventualno nekada možeš da ga vratiš u život ako malo poguraš ili izvadiš osovinu napolje ali samo malo jer se nekad pri padu nabije pa se teško vrti. Četkice su baš to u šta gledaš na slici znači ništa drugo nego dva lima sa po dva perceta i teško da mogu da se potroše osima ako iz nekog razloga se istope zbog nekog kratkog spoja mada pre toga umre esc....
Ležajevi su im ništa drugo nego čaura gore i plastika dole tako da pre umre plastika a posebno ako imaš konstatno pregrejavanje motora iz nekog razloga (ukrivljena osovina, prevelike elise, prevelik korak elise....)
Brushless konverzija je po meni bolja varijanta ali pre toga dobro razmisli jer su ti mikroquadovi sa brushless motorima jeftiniji da ih kupiš gotove nego da sam praviš. Kod većih to nije slučaj. Po meni taj q90 i slični su namenjeni da se nauči neke osnovne stvari kod letenja  multirotorima. VRlo su jeftini to stoji, teško ih je viziti po stanu, kući jer su veliki, spori su i teško agilni. Delovi su im jeftini...
Za kućne varijante whoop je idealan posebno ako se napravi kako treba jer je neuništiv, mali je, osećaj brzine u malim prostorima je fantastičan, okretan je kao čigra i stvarno je dobra zezancija, ali teško da je za vožnju po otovrenom jer je prelagan i svaki mu vetrić smeta. Za dvorišne varijante ja bih pre razmislio o vizardu ili aurori ili nekom novom pošto nisam skoro gledao šta je izlazilo a izlazi stalno nešto novo. Posle ovoga verovatno će me napasti ovi vlasnici q90 sa ovog topika možda sa pravom možda i ne.
Nisam ništa loše mislio samo sam izneo svoj stav. Oni se dobro zezaju i dobro druže što je za ovaj sport najbitnije i svaka pohvala za okupljanje.... Ali onaj ko hoće adrenalin a da pri tome ne strepi da li će padom da menja neki deo ovo sigurno nije quad za njega.
Ja debelo još razmišljam koju dvorišnu varijantu da uzmem tamo na jesen za sada mi lizard nekako najbolje rešenje.
Kuća=WHOOP
Dvorište ili manji parkić=LIZARD
VEĆI PARK=klasa 210
Post by: srkipa on August 26, 2017, 09:40:20 AM
Da malo osvezimo temu
https://youtu.be/sD5KNbDQp7o (https://youtu.be/sD5KNbDQp7o)
Post by: mikijus on August 30, 2017, 11:03:26 PM
i micro i super slika   :)aplauz :)aplauz :)aplauz
https://www.youtube.com/watch?v=7cj0zcIDL3k&feature=youtu.be
Post by: DMZ on November 17, 2017, 12:34:08 PM
Meni ovo letece jaje deluje zanimljivo za sobno igranje, ali s obzirom na nedostatak iskustva voleo bih da cujem misljenje iskunih? :)
https://youtu.be/0zXBSmuqNDk
Post by: marko.jovanovic on November 17, 2017, 12:55:12 PM
Interesantan jeste ali ne i za kuću. Više je za neko dvorišt, manji park, ili neku halu....
Za po kući po meni whoop je nepirikosnoven, ne moraš da brineš o stvarima, deci, samoj letelici nego samo po gasu i udri.
Adrenalin je jednako velik kao i kada voziš 210-250 klasu jer osećaj brzine  malom prostoru je neverobatan, agilnost takođe.
Ja letim sa njim već godinu dana sa istim frejmom, istim propelerima, čak i motore retko menjam jer sam ih doveo sa elisama do tog nivoa da se ne graju a grejanje je glavni uzrok otkaza ovih malih motora jer strada plastični ležaj u njemu.....
KAd mi dosadi namerno ga u punoj brzini spucam u nogu od stolice.....
Ne kažem da se ne može ni ovo voziti po kući ali ni blizu slobode kao kada voziš whoop-a osim toga ovde su propeleri potpuno nezaštićeni pa ako se jurca po kući svaki pad može da rezultira zamenom propelera.....
Post by: mikijus on November 17, 2017, 03:12:43 PM
ja cekam da se pojavi runcam split za mikrace na 20x20mm stack-u
...mislim to mi je plan za sledecu sezonu a do tada po kuci qx90 naravno i to bez zastita....
cudo kako vam za godinu dana poraste skil....na pocetku mi nikakva zastita nije pomogla da ga ne olipam par puta po kuci...
srecom naj cesce ode elisa , mada sam i 4-5 motora promenio a i 3-4 rama....ali to je vec druga prica .......
evo jednog smesnog videa kako sam leteo po kuci   pre pojave mikro quadova:)
https://www.youtube.com/watch?v=eqZ8b2Be2iQ
Post by: sman on November 17, 2017, 03:17:00 PM
Evo vam za po kucu jeftinooo...
(https://s7.postimg.org/a7q6w43mz/IMG_8483.jpg) (https://postimg.org/image/saj9nbzhj/)
Eachine E011 Mini
Post by: mikijus on November 17, 2017, 03:38:54 PM
dodje mu na kraju isto kao i qx90 na popustu za frsky (platio sam ga 23.50 e)posto nikako da nadjem baterije koje salju u srbija za njega idu s1 na 260mah i sa nekim drugacijm dzekom mada mogu i standardni prosekli su dzek na quadu....ali ipak naj veca mana mu je kontroler koji nije f3....
Post by: DMZ on November 17, 2017, 03:55:10 PM
Jaje mi se svidja najvise zbog toga sto moze da se ubudzi runcam split, pa svo to zezanje moze i lepo da se snimi. I bas to sto moze za po kuci, a i po parku i dvoristu... U sadnje vreme sam poceo previse da se glupiram sa Sparkom, a to definitivno nije bas pametno :) Idu neki prop. guard-ovi uz njega... Verujem da je whoop bolji za po kuci, ali solidna kamera u ovako malom pakovanju su mi neodoljivi. A kasnije mozda dodje i whoop.
Bitno mi je bilo misljenje po pitanju konstrukcije, rama, zasticenosti komponenti... Ti prop guardovi ce koliko toliko da pricuvaju propelere i motore, decu sam rasterao, za zenu nije steta jedino ce ljubimci malo morati da se prilagodjavaju novom drugaru :)
Post by: marko.jovanovic on November 18, 2017, 10:33:25 AM
https://www.youtube.com/watch?v=BUl6PooveJE
EHEHEHEHE
Post by: mikijus on November 18, 2017, 11:59:33 PM
