AERIAL PHOTGRAPHY => FOTOGRAFIJE i VIDEO SNIMCI => Topic started by: monsun on March 21, 2008, 11:35:05 AM
Title: slike
Post by: monsun on March 21, 2008, 11:35:05 AM
kada ce kod nas biti nesto poput ovoga(http://i297.photobucket.com/albums/mm212/monsun_2008/2005-joe-nall-01b.jpg) (http://i297.photobucket.com/albums/mm212/monsun_2008/2005-joe-nall-01b.jpg)
(http://i297.photobucket.com/albums/mm212/monsun_2008/IMG_6828.jpg) (http://i297.photobucket.com/albums/mm212/monsun_2008/IMG_6828.jpg)
(http://i297.photobucket.com/albums/mm212/monsun_2008/jet_wm_004.jpg) (http://i297.photobucket.com/albums/mm212/monsun_2008/jet_wm_004.jpg)
(http://i297.photobucket.com/albums/mm212/monsun_2008/IMG_7273.jpg) (http://i297.photobucket.com/albums/mm212/monsun_2008/IMG_7273.jpg)
(http://s297.photobucket.com/albums/mm212/monsun_2008/th_2005-joe-nall-05b.jpg) (http://s297.photobucket.com/albums/mm212/monsun_2008/th_2005-joe-nall-05b.jpg)
Title: Re: slike
Post by: srpska posla on March 21, 2008, 01:13:52 PM
...upravo to: Rim nije izgradjen za jedan dan.
Voleo bi' da gosn. Robin Hud otvori tako nesto kod nas,  a ne ovi sto nas muzu stampajuci dinare.
U medjuvremenu dok se te banke ne otvore , ima dosta stavri koje bi mogli oko svoje kuce das pospremimo.
Npr. ovi "posrednici" sto uzmu  35% na cenu robe i plus uzmu za sebe pdv !  Zatim razni Zastupnici i Zagovaraci Modelarstva koji zloupotrbljavaju tuDj entuzijazam i neobavestenost za kratkotrajnu dobit....
Ako 'vako nastavim ode ovaj topik u...
..a, ovo je klasicni Mine is bigger than yours skup, materijala za tako nesto imamo na pretek!
Pozdrav!
Srpska Posla
Title: Re: slike
Post by: SABURO on March 21, 2008, 04:22:38 PM
bice, samo je pitanje vremena.
Title: Re: slike
Post by: magic on March 21, 2008, 06:36:31 PM
Evo ako mogu i ja da dam svoj komentar posto sam skoro 8 godina ziveo u inostranstvu, doduse ne i u Americi. Meni ovo definitivno lici na neko svetsko prvenstvo ili na neko vrlo retko a jako bitno okupljanje. Nemojte misliti da je tako lako i u inostrantvu baviti se ovim hobijem. Uvodjenjem Eura u Evropi ruze mnogo manje cvetaju! Lakse sigurno jeste nego kod nas ali slika koja je zapocela diskusiju mislim da je generalno retka i u svetu za videti.
Ja kad pogledam slike sa nasih okupljanja mogu da kazem da sam ponosan sta sve kod nas ima da se vidi. Kako su ljudi, koji su u ovom hobiju kod nas, uglavnom jako dobro obavesteni mislim da se ovde voze dosta kvalitetni modeli a koji ne kostaju previse. Kada su modeli na struju u pitanju mislim da danas pored UH moze svako da kupi barem kvalitetnu opremu za vrlo pristojne novce. Ispostavilo se za modele da je ipak malo bolje kada su "firmirani".
A kada ce nesto onako biti i kod nas? Pa ja se iskreno nadam za jedno 3-5 godina. Naravno ne u toj kolicini ali necu se iznenaditi ako za 3 godine na nekom nasem okupljanju bude preko 10-15 modela raspona veceg od 2m na benzinske motore.
Title: Re: slike
Post by: magic on March 21, 2008, 11:15:29 PM
Kako bih potvrdio moju gore navedenu tvrdnju evo par linkova za velike avione u Svaji:
Giles od 192cm i 26ccm za 500 Eur!
http://www.der-schweighofer.at/web/productdetails.php?artikelnummer=65487&prodID=100
Yak 54 od 193cm i 45ccm za 500 Eur!
http://www.der-schweighofer.at/web/productdetails.php?artikelnummer=72138&prodID=100
Extra 330 sa trupom od kompozita od 196cm i 45ccm 500 Eur!
http://www.der-schweighofer.at/web/productdetails.php?artikelnummer=65481&prodID=100
i
Extra 216cm sa 65ccm za 560Eur!
http://www.der-schweighofer.at/web/productdetails.php?artikelnummer=72137&prodID=100
Na ovo jos elisa, servoi i sigurno jos neke sitnice, sve ukupno za 100Eur, pa racunajte sami! Ako ja saberem koliko me je kostao moj SU29a to je 500 Eur bez baterija  :o izgleda cemo i mnogo ranije da vidimo one silne avione!!!
Jedina mana je sto benzinca covek ne moze da drzi u kuci, mirise isto koliko i kosilica za travu  :( i sto nije jednostavno za transport, ali zato  ;) ...
Title: Re: slike
Post by: kole on March 22, 2008, 01:54:49 AM
pa da vam i ja kazem koju. Elem, u Kanadi je retkost videti velike modele jer su i sami tereni za letenje mali i okolina je obavezno zauzeta i prebukirana. Kada opicis sa malim modelom u nesto to je jedna stvar a kad skrkas onakvu masinu, to je vec ozbiljna stvar.
Ima skupova, nije da nema, ali se pretezno voze modeli oko 1.5m ili neke sobnije verzije.
Kad sam se raspitivao za jedrilice, kao da sam se raspitivao za satlove, valda im to nije interesantno ili je previse zamorno, pojma nemam.
Ajd' u zdravlje...
Title: Re: slike
Post by: Dejan Dobricki on March 22, 2008, 03:19:14 AM
e pa ovako da i ja nesto kazem obicno se ustezem da komentarisem neke postove gde bih nekoga uvredio ali ovde necu nikoga pa cu biti slobodan da dam neki komentar.
kod nas ce biti tako nesto onog momenta kada neki od roditelja koji nema nikakave veze sa modelarstvom pokupi svoje dete i dodje na miting da bih video nesto o cemu ne samo da deca mastaju nego i odrasli pa ti mitinzi predju u tradiciju pa taj roditelj sledece godine povede i neke svoje prijatelje sa decom i to tako ide lancanom reakcijom i onda se nadje futaba i ko zna koji jos prizvodjac koja to kroz tu lancanu reakciju roditelja vidi dobro trziste i nadje ljude koji ce se ne takmiciti nego paradirati po mitinzima sa velikim modelima da bih prodala svoje proizvode ovi ljudi ovde nose dresove futabe a evo vam i link da ih uporedite po bojam tj slicnosti
http://www.futaba-rc.com/
nijedan od tih ljudi nebi nalepili ni jednu malecku nalepnicu nekog prizvodjaca da nema koristi od toga jer je takva svest tih ljudi ,tako da mislim da smo na dobrom putu hm dali smo pitanje je sad jer kada to vreme dodje mislim da ce to sve postati komercijala nece biti Giletovog rostilja nece biti mitinga na kojima cemo se okupljati da bih kao leteli a ustvari druzili i pricali ,da prodjem kao ja odes na miting gde nema modela ispod 20 ccm a ja doneo mali od 8 ccm pa me sramota izneti iz auta a kamoli leteti i ako mozda bolje letim od mnogih ali jedno sigurno znam da sam isti a mozda i bolji od onoga bio koji je imao najveci model ali taj je dosao samo da se reklamira i prodaje tako da ne treba zaliti za time ako trba da dodje i mito trazimo da dodje doce samo je pitanje kada.
a ikada pogledas pa i kod nas je bilo takvih okupljanja prosle godine mislim u tom broju samo sto ovi imaju vece modele pa su se morali vise rasiriti gabaritno ;D ;D ;D ;D ;D ;D ;D
uzdravlje
Title: Re: slike
Post by: GILE on March 24, 2008, 10:56:31 AM
Pozdrav od Gileta
Kao prvo i ako cu da se ponavljam iza Sabura molim sve koji pisu na forumu da se ni na koji nacin ne doticu Politike i Crkve u napred sam vam zahvalan.
Kao drugo kada smo planirali proslogodisnji skup u Beogradu zvao sam mog poslovnog saradnika iz Slovenije koji drzi firmu MIBO, a ujedno i proizvodi mlazne modele, da dovede nekoliko ucesnika sa mlaznim modelima. Odma je prihvatio poziv i dao mi obecanje da moze da dovede  3-4 modelara koji lete mlazne modele. Sav sretan pitam sta su nase obaveze. Odgovor je bio u pocetku vrlo jednostavan dva dana da lete po nekoliko startova da je pista prihvatljiva i da imaju klopu i pice.  ??? Predpostavljam da ste svesni koliko je tesko dobiti aerodrom za jedan dan a kamoli za dva.  ;) To bi nekako iresio ni klopa mi nije problem ali pice nece  :o vodu. A onda se upitah kad bi mi leteli ako oni lete znaci mi smo samo posmatraci. Zelja da dovedem malazne modele da ih vidim kod nas me nije napustila. Mozda ove godine ako se kockice sklope.
Toliko od Gileta
Title: Re: slike
Post by: skywalker on March 27, 2008, 12:02:21 AM
Pozdrav za sve,
pa kako sam poceo da se lozim na impelere, u svojoj kolekciji 3 komada, mislim da cu do godine da kupim i turbinu sa f-16 ticom tako da ako ovi iz Slovenije ne dodju gledacete mene ;)
nije to sada ni toliko skupo a bice samo jeftinije!
Pozdrav, Bozidar
www.avioni.tk
